Any plans for polk to release an even newer version of the SDA tweeter
MAD
OK I'm totally sold on upgrading the tweeters to the RDO 194 and eventually caps on the crossover but is there any talk of an even newer tweeter that they are developing and planning to modify it to suit the SDAs.
I know the lsi series has a dual ring radiator etc.
When was the rdo 198 and 194 released?
I would hate to fork out all the cash and have an even better tweeter become available especially since I am really enjoying the SDA SRS 2.3 as they stand. I could easily listen for a year or so while waiting.
Thanks for the replies in advance,
Mike
Mike
Post edited by MAD on
Is there that big a market for SDA tweeters?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I doubt if Polk will ever release a newer tweet for SDA's. I think we are fortunate that Polk upgraded the originals, most companies would not have.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
Agreed. I had hoped that someday they would release a new SDA but I don't think so, the reason I am glad to have what I have.I doubt if Polk will ever release a newer tweet for SDA's. I think we are fortunate that Polk upgraded the originals, most companies would not have.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Not going to happen and why should it, the RD0 tweeters are great.Political Correctness'.........defined
President of Club Polk -
Why fix something that isn't broken? The 194s are great tweeters, and the 198s are superb. It's hard to beat a properly designed textile dome tweeter. I'm grateful Polk developed these new tweeters. I'm not aware of any mass-production audio company that has done anything even close to what Polk did. I'm not naHome Theater/2 Channel:
dhsspeakerservice.com/ -
It seems to me that generally the RDO 198 is the tweeter to get... as a few of you have said...a bit brighter top end vs. the 194 more laid back. I really like the top end sizzle and airyness in a speaker.
Some people have put an entirely new crossover in their SDA SRS 2.3 to convert them to TL and then put the 198 tweeter in.
Is there a simple change I could make to my crossover (just changing a couple caps and resistors) to accomodate the 198 tweeter instead of the 194? I'm planning to do a recap eventually anyways.
Would it be better to wait for a set of 2.3tl to pop up?
Thanks for the advice -
I don't know that I'd describe them as brighter, just smoother and more detailed.
To my knowledge there is no TL mod for your 2.3s, the crossovers and drivers are vastly different than the 2.3TLsHome Theater/2 Channel:
If you use the 194 tweeter and use a jumper (instead of a .5 ohm resistor) to replace the polyswitch(s), you might get a little brighter top end that you prefer. No cap replacement would be needed and the cost would be $0 if you can solder.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
yea and if it is a little too bright go with a .22 Mills Resistor they are cheapIf you use the 194 tweeter and use a jumper (instead of a .5 ohm resistor) to replace the polyswitch(s), you might get a little brighter top end that you prefer. No cap replacement would be needed and the cost would be $0 if you can solder.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
Thanks for the ideas... guess I'll just try them out and see
You didn't say what your driving them with, but if you're worried about amp clipping (or of course over-driving), then I would think twice about "jumpering" (shorting) the poly-switch. Don't get me wrong, getting rid of the PS was one of the best things I ever did, but I replaced it with a .5 Ohm resistor even though I've been using the same Yamaha amp for a decade and was very happy with the results.Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
The way I see it the .5 ohm resistor offers no more protection from clipping than the jumper would. The resistor is only installed to add the approximate resistance of the PS to keep the circuit as near to factory specs as possible. Otherwise the resistor is nothing but a jumper. The PS is basically a circuit breaker. A resistor will not serve the same purpose as far as I know.You didn't say what your driving them with, but if you're worried about amp clipping (or of course over-driving), then I would think twice about "jumpering" (shorting) the poly-switch. Don't get me wrong, getting rid of the PS was one of the best things I ever did, but I replaced it with a .5 Ohm resistor even though I've been using the same Yamaha amp for a decade and was very happy with the results.- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
Correct. -
Since being a brand new owner of SDA 2BS w/ vertical mount Silver dome tweeters is replacing these things THAT much better or again subjective and if not blown should I even consider a change.I really can't afford mods and going nuts in a good way would be out of the question. My more pressing problem is those deep water stains on both tops and I have reached out to the appropreate peeps F-1 and the process seems frought w/ danger w/ acid ,stripper , and other chemicals then sanding then refinishing,I'm not so sure I will attempt this not to mention that I would have carefully remove caps and bottoms to do this.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
leftwinger57 wrote: »Since being a brand new owner of SDA 2BS w/ vertical mount Silver dome tweeters is replacing these things THAT much better or again subjective and if not blown should I even consider a change.I really can't afford mods and going nuts in a good way would be out of the question. My more pressing problem is those deep water stains on both tops and I have reached out to the appropreate peeps F-1 and the process seems frought w/ danger w/ acid ,stripper , and other chemicals then sanding then refinishing,I'm not so sure I will attempt this not to mention that I would have carefully remove caps and bottoms to do this.
You will hear an improvement if you just replace the tweets. Need some time to round out though.
