Excellent Denon PMA 2000IVR high current integrated amp with remote and phono
geppy1
geppy1 Posts: 3,076
edited June 2013 in For Sale (FS) Classifieds
I cannot seem to hang on to anything as bills keep coming. sooo For sale is a very nice Denon PMA 2000IVR with remote,phono stage. This is the latest and improved version of the PMA 2000R which was on Stereophie's recommended List for a few years. Uses Ultra High Current MosFets and a true dual mono design. Can drive almost anything and sounds somewhat more open and has a more dynamic sound then the original. One of the few amps I have heard that produces an almost holographic stage with some tracks. Has a very nice phono section and part of the change over the original 2000 is the inclusion of a preamp out and a poweramp direct. This allows you to use it in a HT system if need be. The feel and build quality is off the charts. It weighs 52lbs. It is in beautiful conditon and everything perfectly In excellent shape. Includes Denon PMA2000IVR , original power cord, manual, and Sony universal remote control More info below. Asking $495 Thanks,KG
Now get the amp and preamp incorporated in one chasis with the Denon PMA-2000 amplifier. With this Denon 2-channel amplifier you can easily plug in your stereo systems into one unit to listen to music with a breathtaking sound. The Ultra-high-current UHC-MOS circuit of this Denon amplifier provides the perfect combination of power and precision. With dual power transformers, this Denon 2-channel amplifier provides 80 watts per channel output. The chassis of this Denon amplifier is divided into six heavily shielded blocks. The Denon PMA-2000 prevents the interference between two channels to give out a clear sound without any humming.
Product Identifiers
Brand Denon
Model PMA-2000 IV R
MPN PMA-2000 IV R
Key Features
Frequency Response 5 Hz - 10 kHz
Number Of Channels 2
Tech Details
Audio SNR 74 dB
RMS Power at 4 Ohms 160 Watt
RMS Power at 8 Ohms 80 Watt
THD (Total Harmonic Distortion) 0.01 %
Remote Control Without Remote Control
Bridgeable Not Bridgeable
Dimensions
Depth 18.75 inch
Height 7.1 inch
Width 17.1 inch
Weight 52 lb
001.jpg 471.7K
003.jpg 439.4K
004.jpg 514.9K
005.jpg 531.2K
006.jpg 511.1K
Post edited by geppy1 on
  • zingo
    zingo Posts: 11,258
    edited June 2013
    Very nice looking integrated, and a step above most integrateds; can't beat it for the price.
  • marvda1
    marvda1 Posts: 4,963
    edited June 2013
    i had this amp a few years back and it's 80 watts outperformed denon's top $3000+ ht receiver. add a small tube preamp as the preamp section is it's minor weak point and this integrated will blow a lot of amps out the water.
    Puritan PSM156
  • geppy1
    geppy1 Posts: 3,076
    edited June 2013
