Power on and off
emm0527
emm0527 Posts: 2
edited May 2013 in Troubleshooting
I have had the polk audio surroundbar 3000 for over a year now and I have programmed my remote to turn the sound bar on and off. If I am lying on the couch and turn the bar on it will come on but it will not turn the tv on unless I get up and point the remote over the sound bar. Is the bar supposed to turn the tv on and off or is the programming just to have the remote work for the bar? Should I have the tv on a platform above the bar? Thanks.
Post edited by emm0527 on
  • Poolgod69
    Poolgod69 Posts: 184
    edited May 2013
    It just seems you are blocking the TV sensor.
    You also may be able to program your cable remote to turn everything at least on at once if your remote is not a universal one.
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    Elemental Designs A2-300 Subwoofer
    Panamax M4300-PM Power Conditioner
    Working on updating my set up :rolleyes:
  • emm0527
    emm0527 Posts: 2
    edited May 2013
    It is a direct tv remote. That was my question. Is the bar supposed to be able to turn your television on if you program the bar with the remote?
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited May 2013
    Hello emmo0527,
    Welcome to Polk's forum. No, the SB won't turn the TV on. It's a good idea in such cases as yours, but alas it won't.
    Regards, Ken
  • johnson33445
    johnson33445 Posts: 2
    edited May 2013
    that's write It is a direct tv remote. That was my question. Is the bar supposed to be able to turn your television on if you program the bar with the remote?have a good time
    Allen123
