Has the SDA SRS Crossover Upgrade 'Parts List' Changed Since DarqueNight did it?
Alwishus
Alwishus Posts: 58
edited April 2013 in Vintage Speakers
I'm having an issue finding one of the capacitors in the list below: 91uf is what DK used (Solen), but can't find it. Has anyone upgraded their SDA SRS crossovers close to this grocery list? Thanks folks.
Capacitors (quantity per speaker): 4.4uF (1), 12uf (1), 20uF (2), 92uF (1), 130uF (2).
Resistors(quantity per speaker): 2.7 ohm (1), 7.5 ohm (1), 15 ohm (1), 22.5 ohm (2).
A 4.4 uF and 92uF capacitor was unavailable in the Solen PB series, so I used 4.3uF and 91uF respectively. The small differences between the stock and upgrade parts was within the 5% tolerance range of the original part
A 22.5 ohm part was unavailable, so I used 22 ohms. The 0.5 ohm difference was within the 10% tolerance range of the original part. (Mills MRA-12 wire wound resistors, Solen PB series polypropylene film capacitors)
Have fun.:)
Post edited by Alwishus on
