Wiring Moniter 10 Tweeters
Faustin
Faustin Posts: 1,149
edited April 2013 in Vintage Speakers
Bought a pair of replacement tweeters for my 10A's from Midwest Speaker. Not sure which wire goes to which side. One black and one white wire in the cabinet. The replacement speaker has a white terminal and a reddish orange terminal. I am assuming white to white. Would that be correct?
Post edited by Faustin on
  • PolkieMan
    PolkieMan Posts: 2,446
    edited April 2013
    Yes but wait why didn't you get exact replacements from Polk Audio?
  • Faustin
    edited April 2013
    Actually, these were the ones that Polk suggested.
  • Faustin
    edited April 2013
    The originals were Peerless made in Denmark
    F1nut Posts: 50,753
    edited April 2013
    Black or blue wire is positive. White or green wire is negative.
  • canadianicon25
    canadianicon25 Posts: 200
    edited April 2013
    let us know how those peerless copies sound. i am curious if they match up okay with original peerless.
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2013
    Faustin wrote: »
    The redish terminal is normally positive, and as F1nut said, the white is negative, and the black is positive.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Faustin
    edited April 2013
    Put the Peerless clone tweeters in and they sound good. Of course I don't have another set of 10's with the original Peerless tweeters to compare side by side, but they look the same (with the exception of the hole in the center) and they sound better than the knock-offs I had in them. I would say that if you can not find original Peerless, these are a good option. After almost 35 years the 10's are still going.
    F1nut Posts: 50,753
    edited April 2013
    You're welcome.
  • PolkieMan
    edited April 2013
    Thanks, if I ever find some 10's with bad Peerless tweeters I will remember this.
    Faustin wrote: »
