AMR-130 No sound
tedesco
tedesco Posts: 3
edited December 2003 in Troubleshooting
I have had My set of AMR-130 since last Christmas, they have work great, all of a sudden I have in intermittent sound, I do have sound from the head phone jack of my sound card, unfortunately mostly they do not work, I can get them to work if I complexly power them down for about a hour, they will then work for a short time, I then have to use my headphones.
Post edited by tedesco on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Are the AMR130's powered? Try them in the headphone jack, see if you get anything.
    Cheers,
    Russ
  • tedesco
    tedesco Posts: 3
    Yes they are powered on, like said in my post, I can get them to work by powering them down for an hour then powering them back on, the head phone jack of my sound card works fine. Do the AMR-130s have a Head phone jack I cannot find? The green lights are on both the sub and the satellite speaker, I suspect that the SUB is a little hosed Does Polk sell a replacement?
  • RuSsMaN
    I was asking if the AMR 130's were powered, ie, do they plug into the wall - I get the jist now anyway.
    Have you plugged the AMR into your headphone jack on your sound card? Does your soundcard have other jacks? Line out, etc? Try plugging it into a different jack.
    Cheers,
    Russ
  • tedesco
    tedesco Posts: 3
    AMR-130s are a 5.1 speaker so all of the jacks on my card are populated, I hooked the satellites up my stereo and they work fine, all of the speaker connect to the Sub, via rugular speaker cable, ther is one satellites that is power control that does not, I cannot see a way to hook the SUb or the main satellites up to anything else.
