Feedback on my system
factorz
factorz Posts: 353
edited April 2013 in 2 Channel Audio
Looking for a little direction from of knowledgeable folks here. My current system is the following and I know I can always move up, but it's what my budget allowed.
SDA-1C Modded
Denon DRA-397
Emotiva XPA-2
Squeezebox Touch
Sony TT
I wouldn't say I am unhappy with the sound, but I feel some tweaking could make things better. Currently the speakers are 12" from the back wall and 9" from the side walls. The TV and stand can't be move because of the cable feed. My first thought was to move the equipment rack out of the area and maybe see if I could add some room treatments. So feel free to let me know what I am doing wrong with my placement.
Post edited by factorz on
    F1nut Posts: 50,734
    edited April 2013
    Any chance of putting the TV on the wall, then put all the gear on the TV stand? That would allow you to move the SDA's away from the side walls, which will improve their performance.
  • factorz
    factorz Posts: 353
    edited April 2013
    Not at this time. It's a older DLP so you can't mount it. So you feel there to close to side wall?
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2013
    Take the vertical rack out and put the gear under the TV then move the sda's away from the side walls. Aren't you near me?
  • thsmith
    thsmith Posts: 6,082
    edited April 2013
    Your 1Cs should be 5'-6' apart and 3' from side walls. Wall treatments will help also.
  • marvda1
    marvda1 Posts: 4,904
    edited April 2013
    what are the dims. of your room? any chance of moving the system to the long wall?
    Puritan PSM156
  • dragon1952
    dragon1952 Posts: 4,907
    edited April 2013
    The Touch would be greatly improved by a nice out-board DAC and probably even a PS upgrade.
  • headrott
    headrott Posts: 5,496
    edited April 2013
    factorz wrote: »
    Much, much too close. As thsmith stated, they should be AT LEAST 3' from the side walls. As Marv suggested, can you move them to the longer wall (if it is a longer wall)?
  • factorz
    factorz Posts: 353
    edited April 2013
    The space they are in is what I have to work with for now. Hopefully our next house will allow me to put them along a longer wall to give them more room to breath. Going to see what I can do about getting the rack out of there and moving them away from the side walls. I might be able to get a few room treatments. Should they go along the wall or behind the speakers?
    Leroy I am near you. Opposite side of the city.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited April 2013
    +1 on the addition of a DAC, the right one makes a huge improvement!!! Also ( i assume the denon is used as pre) up grade to better pre and a big improvment can be had as well. But still a nice system.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    heiney9 Posts: 25,204
    edited April 2013
    Yeah, those SDA's are not set-up properly at all. I'm sure they sound decent but you don't have any idea what you are missing by having them crammed in each corner of the room. Eh, the amp could be better but it's probably better than just using a receiver by itself. A real pre-amp would serve you better than an avr and a linear power supply for the Touch helps.
    How far off is the new house? People say that all the time, "when I get a new house" and they end up staying in the current house for 10 more years :lol:
    Enjoy and don't take the criticism personally. You asked and I am being honest from my perspective. If you only did one thing, get the SDA's properly set-up if at all possible
  • drumminman
    drumminman Posts: 3,396
    edited April 2013
    factorz wrote: »
    SDA-1C Modded
    Denon DRA-397
    Emotiva XPA-2
    Squeezebox Touch
    Sony TT
    Why not extend the cable feed so that you can try moving stuff to the long wall? You could either get the cable company out to do it which is probably not going to cost anything, or buy a coupler and some extra cable and do it yourself.
    Once the speakers are set up properly you can reevaluate. The improvement may be to the point that you're satisfied enough with the sound to put off further upgrades . . . or not! :smile:
  • factorz
    factorz Posts: 353
    edited April 2013
    heiney9 wrote: »
    No worries. I have asked for honest feedback and I appreciate what I have gotten. No arguments from me that the equipment could all be improved, but at this time the funds won't allow it so I figure a little tweaking might help.
  • factorz
    factorz Posts: 353
    edited April 2013
    Thanks again to everyone for making some good suggestions. I ended up spending the day moving the entire room around and was able to fit them on the side wall giving them a ton of room on both sides and 7 feet between them. Sound is much improved and now the savings begin for a new pre-amp and DAC.
  • marvda1
    edited April 2013
    that will be a 12 pack for my services:cheesygrin:
    Puritan PSM156
