Monoprice or NOT
Just checking for 30 ft hdmi cables and was told the Monoprice with Redmere would be good. Looking for input
Post edited by gentleman jack on
  • hochpt21
    hochpt21 Posts: 5,423
    edited March 2013
    That is what I purchased for my projector setup.
    It has worked very well so far.
    I have not compared it to anything else, however.
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited March 2013
    I probably wouldn't buy anything from Monoprice again. I've had two HDMI cables fail on me and my speaker wire turned green after less than a year of use. For HDMI on the cheap, I would recommend Tartan Cable: http://tartancable.com/hdmi-cables/index.htm
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • PolkieMan
    PolkieMan Posts: 2,446
    edited March 2013
    I haven't had any failures. I always buy the top end of their offerings.
  • mantis
    mantis Posts: 17,607
    edited March 2013
    I have seen so many Monoprice cables fail in the field . I don't care if they are free , I wouldn't use them in my system. I suggest you look into a Audioquest Forest HDMI cable , it will fit your needs and last a lifetime or at least as long as HDMI is around.
    Dan
  • sodablue
    sodablue Posts: 24
    edited March 2013
    I have quite a few Monoprice cables, and honestly I'll probably avoid them in the future. The only ones I've had fail have been some 3' VGA cables I bought a few years back. The HDMI and DVI cables seemed to work ok. The problem is, the cables were extremely stiff and hard to route. Part of this was because I bought the premium model with the higher gauge wire, but they're making up for low quality components with thicker stuff... have had the same experience with their mounts. Sometimes cheap is good enough, but not if it makes it significantly harder to use.
    I swapped out the HDMI cables on our TV to using GE cables I bought at Home Depot and they work great.
    We have one run in the house that's 25' and that is a Vanco flat HDMI cable installed by the previous owners. That's working great to, and from what I've seen Vanco makes a number of products used by home theater installs.
  • gdb
    gdb Posts: 6,012
    edited March 2013
  • gce
    gce Posts: 2,158
    edited March 2013
    I've had a monoprice HDMI cable fail. I now use Blue Jean http://www.bluejeanscable.com/ with no problems!
    Anaheim Hills CA,
  • RamZet
    RamZet Posts: 792
    edited April 2013
    Im a big fan of the Planet Wave HDMI and the Key Digital Python isnt bad, but the PlanetWave is awesome stuff. Its nice a flexible, the ends are solid and dont snap off + they look nice.
    B&W CM9Classé Sigma
  • eclypse
    eclypse Posts: 595
    edited April 2013
    I've bought 3 of these PipeLine cables from RadioShack for my new tv and they seem pretty awesome to me.
    http://www.radioshack.com/product/index.jsp?productId=12324317
    http://www.radioshack.com/product/index.jsp?productId=12324318
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
    edited April 2013
    sodablue wrote: »
    Just WHAT are you guys doing? Honestly, I have "never" had a cable by "any" manufacturer" fail, "never", "nothing" regardless of whether it is cheap **** or higher end (from HDMI, to COAX to plastic toslink, to super cheap oxidized thin strand (useless) copper speaker wire). NADA!
    I'm still trying to figure out what cable failure "means"! The cabling in my HT has now been in place from 2004-2013. Some is decent quality some is NOT. No problems, no failures? And, no "noticeable" degradation!
    cnh
  • RamZet
    RamZet Posts: 792
    edited April 2013
    cnh wrote: »
    cnh
    Wires fail all the time. The company I work with uses very high end cables. HDMI cables that run for over 600 bucks. Cables that are made to tugged on and stepped on during an installation. I have seen them fail too. on Friday we had a client loose cable image to their tv. ( house has been up and running for over 1 year now.) The TV inputs were good and the cable box output was good. We switched the cable box to the spare HDMI and we had image. This type of stuff just happens. Things fail.
    I worked at Radio-shack about 7 years ago when HDMI and HDTV was new and cool. We would get Monster Cable HDMI and RadioShack HDMI cables back because they didn't work or stopped working. ( at the time I think RCA & Monster Cable were making the cables for Radio-shack.) We would test them and sure enough they were dead.
    My last house I ran some cheap Amazon $20 45' HDMI and it work for a year. One day I turned on my tv and switched to my Apple TV ( that device was using the cheap amazon cable) and it had lots of white snow on the picture. Nothing had changed. My TV had not moved and my equipment rack had not changed.
    B&W CM9Classé Sigma
  • sparkyone
    sparkyone Posts: 1
    edited April 2013
    I would only buy the redmere HDMI cables if you using it for a really long length. Otherwise just get the cheapest one. Im in Australia so the shipping from monoprice is really expensive. Over here you can get a 1m HDMI cable delivered for $5. Ive inlcuded a link to the site
  • Habanero Monk
    Habanero Monk Posts: 715
    edited April 2013
    Parts Express has an affordable cable line up also. I have a 75 foot run with active HDMI extender using CAT6 STP. Also have a pair of MP 6 foot MP 24AWG HDMI on each end. No problems. 14AWG inwall cable (100foot) fine also. No oxidation after 3+ years.
    Monster on Accessories 4 less or ebay is affordable too.
  • Habanero Monk
    edited April 2013
    RamZet wrote: »
    So you've established that not only Mono-price can have issues. I wonder what the failure rate %'s are? Is it safe or not safe to assume the MonoPrice sells more or less than other brands. That the real question: What is the failure % to all cables sold. The bigger the boat the easier to torpedo.
  • Jhayman
    Jhayman Posts: 1,548
    edited April 2013
    No brand is immune to failure no matter what you pay.
    Buy what youcan afford and be done with it.
    I have never had a cable fail in my lifetime so I can't comment on mono price cables, but I've used cheap and expensive HDMI čables and never had a failure.
    edited April 2013
    Lasareath wrote: »
    I find that mono price are good of you are not unplugging the cable. The ends have come off twice at clients houses when they want me to change their set ups.
    So if your installing a projector and not ever moving it then mono piece should be ok. But if you are going to be unplugging that hdmi cable all the time then it's time to use someone else's cable.
    This! If you're always "messing" with your cables sure the ends (connectors) will loosen. HDMI. I have yet to see a failure and mine are not high end by any means. Some have been in place and working for over 5 years, not a one is over $30? Maybe I should get busy "pulling and tugging" on them. lol
    cnh
  • blehmbo
    blehmbo Posts: 179
    edited April 2013
    We've had Monoprice HDMI cables throughout our household for over 6 years and we haven't had any issue with them yet.
    pitdogg2 Posts: 27,530
    edited April 2013
    try these
    http://sewelldirect.com/hdmicable
    work very good I bought the premium
  • amgala
    amgala Posts: 111
    edited April 2013
    I have bought a ton of stuff from Monoprice. The only two issues I've had is with the twist-on end of an optical audio cable not being parallel with the actual male end of the cable, and with a micro USB cable that will only work if it is being propped up. But Monoprice has a lifetime warranty on cables, I just haven't gotten around to submitting for an RMA.
    That said, if you've got the coin, there are nicer cables to be had particularly in the fit and finish category.
    Front Speakers: Polk Audio LSi15 x 2
    Center Speaker: Polk Audio LSiC
    Rear Speakers: Polk Audio LSiF/X x 2
    Subwoofers: Polk Audio PSW505 x 2
    AVR: Denon AVR-3313CI
    Amp: Emotiva XPA-5
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    I use monoprice for a lot of things and have yet to have anything go bad for me. I would recommend them to anyone as they are a great, inexpensive company. I have saved a lot of money as well too, which is always a positive for a college student haha
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
  • samreddevilz
    samreddevilz Posts: 18
    edited May 2013
    I hadn't face any difficulties till now. They are working fine in my set up !
