6 ohm or 8 ohms?
Csa73
Csa73 Posts: 36
edited March 2013 in Troubleshooting
Heya all!! Will i get more watts to my monitor 75t's if i change the ohms to 6 on my yamaha htr 6180? Ive looked in my manual and on line with no success. My manual says built-in 7 channel power amplifier 120w@ 8ohm but on the
yamaha web site it says 105w@ 8ohms. Doesn't give wattage at 6 ohms. And i suppose is it ok to change it to 6 ohms
Since the monitors are rated @ 8 ohms.
    txcoastal1 Posts: 13,519
    edited March 2013
    Nope...Leave at ratings for speaker
