Tube Amp Question
Mikey081057
Mikey081057 Posts: 7,127
edited March 2013 in 2 Channel Audio
Can this tube amp drive my LSi 9's
Output Power:45W + 45W (8ohm)
Frequency Response:5Hz -- 54kHz (-2dB)
Signal/Noise Ratio: >=88dB (A)
Load impedance: 8ohm or 4ohm
Distortion:<=0.35%
Maximum Power Consumption:220W
Input sensitivity:<=200mV
Tubes: 6CA7T x 4 12AX7B x 2 12AU7 x 2
It is a Yaqin MC 13S
Garage | Polk Monitor 5B's
Post edited by Mikey081057 on
  • zingo
    zingo Posts: 11,258
    edited March 2013
  • cstmar01
    cstmar01 Posts: 4,424
    edited March 2013
  • marvda1
    marvda1 Posts: 4,963
    edited March 2013
    there are two versions one comes with el34's and the other with 6ca7's ($100 more). i pull up specs as 40 watts per, though not much difference between 40 and 45 watts. usually 6ca7's will deliver a little more power, especially in the bass region.
    you can buy the el34 version and put the $100 saved towards an upgraded set of tubes.
    i guess a long way of saying yes. have you priced the difference between the 13s and 10t? 40 watts vs. 52 watts.
    Puritan PSM156
  • Mikey081057
    edited March 2013
    marvda1 wrote: »
    So I am seeing the mc -13 for 70 bucks more with 6ca7's than the mc-10 with the el34's
    does that make sense?
  • michaeljhsda2
    michaeljhsda2 Posts: 2,204
    edited March 2013
    The MC-13S doesn't have a remote control but the MS-20L does. Not sure if that's important to you or not. I'm very happy with the MS-20L. Plenty of power to drive SRS 1.2 TL's.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Mikey081057
    edited March 2013
    So actually looking at the MC-100B for just a few$$ more
  • michaeljhsda2
    edited March 2013
    That's a nice amp with the option of using it as an integrated or amp only. It has a little bit more power, 10 more watts I believe, than a MS-20L or MC-10T. The MC100B was my first choice but alas, no remote control, so I went with the 20L.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • marvda1
    edited March 2013
    the 100b uses 6550/kt88 tubes, a different sound. i have tube mono blocks that were designed with 6ca7's in mind even though el34 and 6ca7 are direct drop in replacements. if i use el34's in my amps i would get less power/bass. don't know if the two yaqin 13s are like that but i don't think they would have two different versions if they were not different on some way. why not just offer 6ca7's as an upgrade if they are the same exact amps. just my thoughts. grant fidelity use to carry a rebadged yaqin amp that uses both el34 or 6550's i think. you can now purchase it through another company but would cost more than the yaqins.
    Puritan PSM156
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited March 2013
    Go for the el34 option with those lsi9's as its going to be sweeter on tweeter baby :cool:
    F1nut Posts: 51,997
    edited March 2013
    The 6CA7 version would be a better choice, IMO.
  • Tbone289
    Tbone289 Posts: 661
    edited March 2013
    marvda1 wrote: »
    They aren't different in any way--you're just paying more for the 6CA7 tubes, which doesn't really make sense unless the 6CA7 are of much higher quality than the Shuguang EL34s in the "base" model. The MC13s is just another spinoff of the MC-10L/T, and both power tube types are compatible with both units. I don't believe the 13s differs in power from the 10L as much as the specs suggest. I believe the 10L/T specs are slightly exaggerated.
    Personally, I would buy the EL34 model because you can buy a decent quad of 6CA7 with the $100 you've saved (e.g. Electro-Harmonix) and have two sets of tubes to roll for the price of the unit shipped with the 6CA7s. I prefer 6CA7s in my Yaqin over the EL34s, but I'm not sure I would pay $100 extra for them up front unless I knew exactly what 6CA7s they are fitting them with.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • Mikey081057
    edited March 2013
    Any thoughts on the mc-100b
  • Mikey081057
    edited March 2013
    So I am 99% leaning towards the yaqin mc-100b
  • organ
    organ Posts: 4,969
    edited March 2013
    I doubt the output power will make much difference assuming the power supply and output transformers on both units are equal in quality. Every 3db increase require double the power output.
    I personally would go with the EL34 option. 6CA7 is a direct replacement for an EL34 while the EL34 cannot be used in an amp specifically designed for 6CA7. The 6CA7 is a tetrode while EL34 is a pentode tube. Also, in an EL34 amp, you can use KT77 (direct EL34 substitute)
    The EL34 has a sweeter, warmer and smoother sound. 6CA7 have a more powerful sound with better dynamics, extensions and bass.
  • larry777
    larry777 Posts: 480
    edited March 2013
    I bought the MC-100B in early December and like it a lot. The KT-88 tubes give better bass than the other options you are looking at, along with more power, based on what I have read anyway. The amp is breaking in nicely although not 100 hours on it yet. I just changed the two 12AX7 tubes to Amperex NOS and what a nice difference in sound it made. They say this amp responds very well to tube rolling and I can believe it from this one change. The word is,changing the four 6sn7 tubes will also make a noticable difference for the better. I also liked the feature where you can use the MC-100B as a seperate power amp if you want to add a different preamp. This amp has lots of power and the KT-88's are of decent quality,so they will be changed last. The MC-100B is rated at 60 Watts per channel in Ultra linear mode and 30 Watts per channel in Triode mode.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • Mikey081057
    edited March 2013
    larry777 wrote: »
    I read your other posts, and they helped me make my decsion, I too like the bypass inputs, and will use it to plug in other sources
  • Mikey081057
    edited March 2013
    Ordered it today from tamaac in Canada
    Best deal and service
    Now waiting....
  • larry777
    larry777 Posts: 480
    edited March 2013
    I also ordered mine from Song in Canada. He is good to deal with,and you will see that the amp is well packed for shipping. Great warranty also ( 1 yr parts and labour and another 2 years for parts with support on how to replace parts if necessary) I think you will like the build of this amp.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
  • rromeo923
    rromeo923 Posts: 1,513
    edited March 2013
    I have a MC-10L. I have rolled the EL34's a few time and have not heard much of a difference. The 6N1's in the preamp stage I have rolled with much success, major sound improvement.
    Anyway not seeing much difference in the Power Output tubes.
    Just my two cents. Worth about two cents.
    I got static in my head
  • dhart86
    dhart86 Posts: 1,594
    edited March 2013
    rromeo923 wrote: »
    Which 6N1's sound best to you?
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • Mikey081057
    edited March 2013
    larry777 wrote: »
    all in, he has the best deals.
  • larry777
    larry777 Posts: 480
    edited March 2013
    rromeo923 wrote: »
    You are right from what I have read on the forums. The power tubes these amps come with are supposed to be pretty good overall. Replacing the other tubes for the Drivers and Cathode followers along with the Voltage Amplifiers (12AX7's & 6sn7's) are reported to give the best sound improvement. Although you would think that higher end Output Tubes would also improve the sound at least some. The manual also recommends an upgraded power cord and Interconnects for best sound....which I have done.
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    Yaqin MC-100B
  • marvda1
    edited March 2013
    try eh 6ca7eh. i found them to be an improvement over the stock shuguangs in my 20l.
    Puritan PSM156
  • Mikey081057
    edited March 2013
    MC-100B shipped last Monday hasn't arrived yet. Waiting on good ol United States Postal Service.
