RtiA9 woofer issues
acousticfunk
acousticfunk Posts: 2
edited February 2013 in Troubleshooting
Hello,
Recently purchased the 5.1 RtiA9's, CsiA6, FxiA6, PSW505 with a new Onkyo NR616 and my woofers on the RtiA9's fail my Audessey EQing. Tried biamping and the EQing comes back at 60Hz rather than the full range. Separated the highs and lows on the receiver and when it tests the woofers, it is a quiet and muffled sound and the EQing cannot get a reading and it errors out. Right now they are still separated on the receiver and some sound comes out but not working like it should. I have 100W going to the mids and highs, and another 100W going to the woofers and I feel that I should be getting more out of my speakers.
Any help is appreciated.
Thanks,
Andrew
Post edited by acousticfunk on
    F1nut Posts: 52,149
    That AVR, hell just about any AVR cannot drive the A9's properly. You need a separate amp.
    BTW, you are not bi-amping squat with an AVR. Look up what true bi-amping really is.
  • zane77
    zane77 Posts: 1,696
    You will really need more power to drive the A9's. If you try bi-amping like you are doing it only cuts the power to all of the channels, your amp is only 100 watts with two channels driven really drops off after you start adding more speakers
    Two Channel
  • acousticfunk
    Thanks for the input. Let me see what my budget can come up with...
  • ken brydson
    ken brydson Posts: 9,058
    tell us your budget and we'll spend it for you.:cheesygrin:
  • WastelandWand'r
    WastelandWand'r Posts: 466
    ACFunk,
    You didn't say, but have you just tried driving the A9's by themselves without any of the other speakers hooked up? If you are getting 'sound' that sounds 'right', at least you know that
    the 9's aren't buggered up.
    Don't be trying to 'bi' anything, just ensure the straps are in place on the 9's speaker terminals, plug in your speaker cables, top or bottom, not both and give it a listen.
    As suggested, that receiver, along with many others, aren't going to be comfortable pushing that entire set up comfortably. But, when you get it dialed in I think you will be surprised.
    Enjoy the journey,
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • snake1
    snake1 Posts: 567
    ACFunk,
    I had very similar issues myself when I got started. Onkyo makes a great AVR but as stated above, however it will not drive your A9s to any good capacity. Unfortunately it is true that'll you'll need external amplification for your 9's. I personally spent a lot of money needlessly before I found the amplification solution. Now I have the 12s on an external parasound 2250 (which I highly recommend!!!) I will use my AVR to drive the surrounds and center speakers. Could you go on an amplify the surrounds and center, yes but it should really do fine without if you so choose. NICE setup by the way!!!! You'll enjoy it profoundly!!
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • Thorton
    Thorton Posts: 1,324
    Everyone is right-on with their recommendations. I would first try to correctly configure the Audessey. Get an SPL meter and do it manually if you need to. I don't know why it's failing Audessey. With the speakers you have, I believe that AVR will only moderately (at best) drive them. Hate to say it but you need power! With the right amplification that set-up will sing.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • rtart
    rtart Posts: 852
    Actually, we'll spend your budget ---plus 50% - minimum!!
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
