Polk Audio PSW10 blowing fuse
Smutaya
Smutaya Posts: 5
edited January 2013 in Troubleshooting
Hi I just received this subwoofer today from eBay and as soon as I plug it into the socket with an adapter (I'm in the UK) the fuse blows. Now I tried changing the fuse myself and tried 2 fuses. I also changed the fuse on the adapter to a 3amp and the fuse in the subwoofer still blown. I'm lost as what to do now, any suggestions on what will get it to work? Thanks In advance.
Post edited by Smutaya on
  • ZLTFUL
    ZLTFUL Posts: 5,654
    edited January 2013
    I *believe* the power supply in the PSW10 is a 110-120v non-switchable power supply.
    I also *believe* that the UK is a 220v country (European standard, that).
    Typically, if the markings near the power plug don't specifically say 110/220v (or have a physical switch to go between the 2), then the power supply is not cable of "switching" between input voltages.
    I am pretty sure that is what is causing your problem.
    Unless your adapter is some kind of voltage reduction transformer (instead of just a plug adapter to fit the UK standard plug), you will keep on blowing fuses.
  • Smutaya
    Smutaya Posts: 5
    edited January 2013
    A friend of mine suggested a surge protector. Would this work?
    Will this sub work in the UK? Thanks
  • ZLTFUL
    ZLTFUL Posts: 5,654
    edited January 2013
    A surge protector isn't your problem.
    You are trying to plug a 110/120 volt power supply into a 220/240 volt outlet. You could do this if you had a switchable power supply but the PSW10 is not a switchable power supply.
    You will need some kind of step down transformer to run the sub from the wall outlet in the UK.
  • Smutaya
    Smutaya Posts: 5
    edited January 2013
    I'll look for one and see if this fixes my problem, thank you.
  • DracoAmericanus
    DracoAmericanus Posts: 112
    edited January 2013
    I hate to say this but you may have caused damage to the unit, defently get a step down transformer and hope for the best but in my experience after the second fuse or so it may be toast. Some switchers have a zener diode of sorts that will clamp the over voltage to ground and blow the main fuse, sometimes this diode survives other times it shorts. If it's just a standard transformer PSU you may be in luck
    There is no cure....
    Luxman M117, SDA SRS 2.3, rear monitor 10, back rear bose 4.2, valodyne sub and 2 Onkyo m-504 amps Onkyo TX-NR709
    8mm, 7.62x39mm
  • Smutaya
    Smutaya Posts: 5
    edited January 2013
    Which transformer would work, is it the 100va, 100watt transformer. I'm slighted confused as to which transformer to buy.
  • DracoAmericanus
    edited January 2013
    If my math works va is volts times amps so 1 amp x 120volts gives 120va, that's an easy one. If cost is an problem the 100va transformer is a little underrated but should work for testing, the max draw would be well, when it's very loud. but if you can afford it just get the next size up on the transformer.
    IMHO the 100va should work but it might run a bit warmer under load (for testing that's what i would do, but for normal use get the next size up)
    8mm, 7.62x39mm
  • Smutaya
    Smutaya Posts: 5
    edited January 2013
    Would this transformer work?
    http://www.maplin.co.uk/300w-uk-to-usa-voltage-convertor-265288
    I've tried it with this transformer and it still doesn't work. Is the product maybe faulty?
  • DracoAmericanus
    edited January 2013
    Yes i would think that would work, 300 watts is enough for your sub. If the sub is still blowing fuses with that listed adapter i would send it in for service
    8mm, 7.62x39mm
