psw120 help
polkable
I know this is probably a reciever setting issue but........ i'm hopefully looking for a quick diagnosis and some upgrade options. sony dn-1000 reciever, polk cs400 center, bose 201 fronts and (3) cambridge soundworks cs300s surrounds in a 12x10 room. want to keep my soundworks surrounds but want to upgrade to polk fronts and fix my sub problem. No red or green light and no sub sound:frown: easiest test for sub or best replacement if its dead. best replacement of front lt/rt for my setup. not too crazy its a small room but sounds great except for the sub problem now. any help on sub 1st and upgrades 2nd would be much appreciated.
Post edited by polkable on
What will be main use of system; HT, audio, gaming, etc.
Budget would also be good. These people can spend your money pretty quickly.
Do you favor a specific brand or sound?
The more information the better.
If you have no power what-so-ever at the sub, first try another, known good, outlet. Not sure, but may be an easily accessable fuse that can also be checked. Polk Audio has excellant customer service you can contact also.
For Ht, I would probably suggest RTI/A3 if you lean more toward HT. Really good speaker for about any budget. -
thanks for the reply rpf65, the problem with the psw120 is the fuse although i am having a tough time locating the proper one. I will attempt to replace it (ONCE ONLY) as i know if it blows again I've got bigger issues. My personal belief is power a surge caused this. For the upgrade question..... i am looking for the best matching fronts for the cs400 center and psw120 sub and would like to stay with polk.
