Wright Audio
cstmar01
cstmar01 Posts: 4,424
edited January 2013 in 2 Channel Audio
Has anyone experience with some of the newer products from Wright Audio? I know some members have older stuff by them that is good, and it seems like they are still putting out some nice gear for decent prices.
http://www.wrightaudio.us/royale_se_power_amp.htm
I'm not a fan of the inputs on the front with the speaker outputs on the back, however, this thing is beautiful and wonder if it sounds as good as it looks.
The pre amp looks interesting as well.
Post edited by cstmar01 on
  • bobsauto49
    bobsauto49 Posts: 973
    edited January 2013
    Sure looks purrrty!! I didnt need you to post that link!:mad:
    "Everything I ever did in my life worthwhile I caught hell for"
  • ZLTFUL
    ZLTFUL Posts: 5,657
    edited January 2013
    You know what they call a quarter pounder in France?
    Sorry...couldn't resist! :lol:
    I have a friend who has that exact same amp. And he absolutely adores it. He must love it because he said the ONLY thing he doesn't like about it is the shiny parts show fingerprints so his wife always knows when he has been fondling his amp. :lol:
    As far as sound, well...it sounds like a quality tube amp. I know that is rather generic but that pretty much sums it up. Hehe.
    If I could get a good price on one (or my wife wouldn't kill me for bringing more gear home), I would pick one up without hesitation.
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    WHy do companies put the inputs in the front ?
    DOes not work well with MIT S3 ICs.
    Otherwise nice looking amp.
  • marvda1
    marvda1 Posts: 4,905
    edited January 2013
    funny, they give this warning about using other tubes in their amps and then go and use one of the most unreliable tube manufacturers.
    (1) 6N1P (Balanced Sections) and (1) 5AR4 - $ 35
    JJ KT77 Matched Pair - $ 45
    JJ 6CA7 Matched Pair - $ 42
    Matched Pair Reproduction Tung Sol EL34B - $ 58
    ________________________
    Use of Tubes Not Approved
    Single-ended amplifiers require tubes of the highest quality for amplifier reliability. Sadly, there are good-sounding tubes which may be used in push-pull amplifier designs but are not suitable for use in any single-ended amplifiers. Using them will cause the tubes to fail prematurely and likely cause damage to the amplifier.
    Use only tubes recommended by Wright Audio. Evidence of the contrary causing damage to an amplifier is not covered by the Warranty.
    Puritan PSM156
    SCompRacer Posts: 8,520
    edited January 2013
    thsmith wrote: »
    I hear you on the inconvenience. It is usually done to keep the signal path short to the input tubes. If the inputs were at the rear, routing and shielding of the wiring to the input tubes would be important to prevent noise passing all the high voltage circuits/output trannies. I had a tube amp with front inputs. The folks that got the rear inputs (same amp) complained of a high noise floor.
  • cstmar01
    edited January 2013
    hmm I have nothing I could really run on this but the thought would be nice to try out someday a high eff. speaker combo with an amp like this.
    Only thing I know of for super high eff. is mostly horn stuff like Klipsch etc. I think there are a few drivers out there but nothing that I know of.
