Favorite Preamps - Best BANG for the $$$
dee1949
dee1949 Posts: 1,425
edited January 2013 in The Clubhouse
...my favorites are : 2 channel
B&K pro10mc
Acurus RL11
Carver C-1
Kenwood Basic C-2 (cheapest )
...have a friend looking for a deal on a GOOD preamp.
Post edited by dee1949 on
  • rromeo923
    rromeo923 Posts: 1,513
    edited January 2013
    Yaqin ms-12b tube pre w/phono and one linestage- very affordable and very nice. pm me if your friend may be interested. I am sellingand am in Maryland.
    I got static in my head
  • PSOVLSK
    PSOVLSK Posts: 5,371
    edited January 2013
    Though this seems like a shameless plug, I honestly wouldn't mention it if I didn't feel like it was a great bang for the buck pre. NAD 116 I have in the FM is tough to beat at the asking price.
  • zingo
    zingo Posts: 11,258
    edited January 2013
    Luminous Audio Axiom II passive preamp
  • jmwest1970
    jmwest1970 Posts: 846
    edited January 2013
    There's not shame in my game. I've enjoyed the Arcam Alpha 9 preamp that I have in the FM for several years. I don't think you'll find anything as smooth in a pre unless you go tubes.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited January 2013
    zingo wrote: »
    +1 on this.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2013
    Adcom GFP-750
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • zingo
    zingo Posts: 11,258
    edited January 2013
    Dawgfish wrote: »
    +1 on this.
    You can't do much better for a new preamp than one that's custom tuned to the specs of your system for a couple hundred dollars.
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    P1010187.jpgWright WLA-12
    Anthem Pre 1L and 2L
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2013
    Bang for the buck? The Parasound PH/P-850 was a steal when available.
    EndersShadow Posts: 17,687
    edited January 2013
    zingo wrote: »
    If only it had a phono input and a remote :biggrin:......
    Althought I dont know if its possible for a passive to have either of those options.....
  • zingo
    zingo Posts: 11,258
    edited January 2013
    Phono, probably not.
    But some recent conversations with Tim from Luminous hinted at releasing a remote control version, as well as a ladder relay version would give more awesome options and flexibility to an already great product.
  • sda2mike
    sda2mike Posts: 3,131
    edited January 2013
  • Dawgfish
    edited January 2013
    zingo wrote: »
    That sounds sweet. I love my Axiom pre, but I often wish it had a remote, but not at the cost of sound quality.
  • zingo
    zingo Posts: 11,258
    edited January 2013
    The ladder relay version would most likely use discrete resistors which should increase sound quality over the current pot. The remote control option would then operate that attenuator, or the current ALPS pot, so no loss of sound quality either way.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited January 2013
    +1 on the dared
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2013
    steveinaz wrote: »
    Beat me to it, +1
  • Conradicles
    Conradicles Posts: 6,331
    edited January 2013
    Toolfan66 Posts: 17,991
    edited January 2013
    sda2mike wrote: »
    dared sl2000a
    +1 on the dared
    I'm probably the only person here to say this... Ehhh:neutral:
  • sda2mike
    edited January 2013
    You're a Canadian! :) you what they say abt opinions...with the dared: for every "ehhh"
    , there's 30 "YES!" votes. just sayin
    edited January 2013
    And that's fine. I'm just not a big fan. The more time I spent with it the less I desired it..
    It has not been fired up in months still like brand new collecting dust. W4S blows it away!!! I would take anything mentioned above over it..
  • Conradicles
    edited January 2013
    zingo wrote: »
    If this happens I would buy one. Thanks for the post I have never seen or heard of this one.
  • Dawgfish
    edited January 2013
    zingo wrote: »
    Sweet. I'll definitely be in line for one of those in my second system.
  • sda2mike
    edited January 2013
    Toolfan66 wrote: »
    interesting..no pre is permanent..i'll put it on my list, the w4s
  • sda2mike
    edited January 2013
    which one is the w4s?..
  • Dawgfish
    edited January 2013
    Oh yeah, I also recommend the Anthem Amp 1 and 2 like Tracy suggested. Another great bang for the buck tube pre that I am currently running is the YS Audio Symphonies +R SE. It has very high build quality, a remote, and sounds awesome.
    tonyb Posts: 33,067
    edited January 2013
    That Luminous looks interesting, especially for the price. I still don't get the thing about how they run the ground, seems like some could run the possability of doing damage to other gear. If these pre's are supposedly tuned to your system, how then do you rotate gear in and out ? Does that mean every time you want to try a new piece of gear you have to send this pre back to get re-tuned ?
    BTW- comparing the W4S to the Dared.....a bit of a price difference there dontcha think ?
  • fbm211
    fbm211 Posts: 1,488
    edited January 2013
    I RATHER LIKE MY MONARCHY M-10 preamp. A thousand doller pre I got for 300
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited January 2013
    I can't say it's the best since I have not heard every other pre-amp available but it sounds damn good.
    Anthem PRE2L paid about $600.00 for it used then
    about $400.00 in tubes
    $50.00 in upgraded caps
    a little dynamat
    maybe $50.00 in tube dampers
  • 11tsteve
    11tsteve Posts: 1,166
    edited January 2013
    dee1949 wrote: »
    B&K pro10mc
    Acurus RL11
    Carver C-1
    i have the RL11 and would really like to do something new but not sure where to go. i would like to try a tubed pre, budget is a consideration ($500) and it really seems the Dared is the only real consideration....
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    tonyb Posts: 33,067
    edited January 2013
    Yaqin too in that price range.
