Why the resistor change from 2.5 Ohm -> 2.0 Ohm in the Model 10 Crossover Schematic?
StantonZ
I'm thinking about rebuilding the crossovers and replacing the tweeters in my 10B's again (although still uncertain whether to go with RD0-194 or -198), and noticed this resistor value change from the 1984 schematic to the 1989 schematic. Why/which value should be used, and is it tweeter type dependent?
(2) Polk RC80i (Top Middle)
Polk CS300 center channel
Post edited by StantonZ on
Use the resistor value in the schematic for your 10B. The earlier model used a different tweeter and that is probably the reason it had a different resistor. You have the sl2000 tweeter in your 10B. The RDO-194 sounds much better.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
So WHICH schematic? One has a resistor value of 2 Ohms, the other 2.5 Ohms. Which one goes with the 194's?Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets
Same answer to the same question.Use the resistor value in the schematic for your 10B. The earlier model used a different tweeter and that is probably the reason it had a different resistor. You have the sl2000 tweeter in your 10B. The RDO-194 sounds much better.
I just rebuilt a pair of 10s for a customer and put the 198s in, along with all the other changes. The difference was stunning to say the least.Home Theater/2 Channel:
dhsspeakerservice.com/ -
westmassguy wrote: »The 1984 "original" schematic shows a fuse in series with the tweeter, while the later 1989 schematic shows the Polyswitch. Since everything else is equal, the difference in resistance between the 1 amp fuse and the Polyswitch is most likely the reason for the lower value.
Now THAT makes sense. So if/when I rebuild the crossovers and decide to eliminate the Polyswitch (I have 2 w/fuses and 2 w/Polyswitches), I'll need to adjust that resistor accordingly; if I were to examine the crossovers I bet I have 2 each with different resistor values. I think I'm going with the "drop-in" 194's, but thanks for the schematic reference if I don't.Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
Now THAT makes sense. So if/when I rebuild the crossovers and decide to eliminate the Polyswitch (I have 2 w/fuses and 2 w/Polyswitches), I'll need to adjust that resistor accordingly; if I were to examine the crossovers I bet I have 2 each with different resistor values. I think I'm going with the "drop-in" 194's, but thanks for the schematic reference if I don't.Home Theater/2 Channel:
