Knowing how to match Timber???
I'm looking for a center speaker to match my Boston Acoustic VR-975 towers. How does one find a timber matching speaker?
Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
Crown D-75, Crown CE1000, Crown CE2000
Typically you try to get something in the same series. If not then looks for something that has the same tonal quality. ie: Bright, harsh, detailed, subdued, etcHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator -
The best/easiest thing to do is ask the cs department of the manufacturer. Otherwise, you would try to match the tweeters, lastly trial and error.
The VR 975's had a matching center channel , I'd suggest a search for it. I don't recall off hand the model number. You can also call Boston Acoustics and find out if they have something offered today that would match correctly.Dan
