Resistor Dilemma - Polk Audio LS90
thsmith
thsmith Posts: 6,082
edited January 2013 in Vintage Speakers
I am raising this outside of my LS90 upgrade and tweak post since I need some additional help so I can place my order on Monday.
According to the original LS90 schamatic I should have a 5 watt .8 ohm resistor in my crossover. Even the circuit board in my crossovers has .8 ohms printed but I found a 1 ohm in one crossover and 2 ohm in the other crossover.
They appear to be original. Maybe Polk ran out of .8 ohm resistors (?).
Anyway, by my way of thinking I should just pick up a couple of Mills 5-MRA .8 ohm resistors.
Anything wrong with my logic ?
Thanks,
Tracy
Post edited by thsmith on
  • 20hz
    20hz Posts: 636
    edited January 2013
    .8 to 1 ohm is just 2/10 of a ohm I dont think its audible plus all resisters have some variance .
    I wouldnt worry about it , if the rest of the board is on spec I would replace it with a .8 or a .9 with the .9 you cant go wrong by much either way .
    But it you want to be sure wait untill monday and call polk tech support or maybe someone from plk will writt in on your message
    F1nut Posts: 50,753
    edited January 2013
    Go with the .8 ohm.
  • thsmith
    edited January 2013
    Thanks guys, .8 makes the most sense.
    I guess Polk had some extra resistors laying around and used what was close.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited January 2013
    Made in China?
    thsmith wrote: »
  • thsmith
    edited January 2013
  • gimpod
    gimpod Posts: 1,793
    edited January 2013
    Go with the .8 ohm.
    +1, also go with the 12 watt Mills.
  • thsmith
    edited January 2013
    Why not 5 watts since that is what was spec?
  • gimpod
    gimpod Posts: 1,793
    edited January 2013
    The 12 watt will give you a little insurance and can handle the power better also wont get as hot as a 5 watt would. I'm sure the 5 watt will work fine your call.
  • thsmith
    edited January 2013
    gimpod wrote: »
    thanks, good to know.
  • PolkieMan
    edited January 2013
    ah Mexico good stuff! ....:cheesygrin::eek:
