Cleaning Vinyl on SDA 1C Studios
bzpolksda
bzpolksda Posts: 38
edited January 2013 in Vintage Speakers
Any recommendations on what works best to clean up the black vinyl on the Studio 1C's?
Thank you in advance. BZ
SDA CRS (2 tweets)
SDA 1C Studios
Post edited by bzpolksda on
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    I used PigSpit (original) on mine and they looked great. But thats only because I had some and knew what it could do for vinyl.
    I am sure others have suggestions for more conventional sources.
    http://www.pigspit.com/
  • bzpolksda
    bzpolksda Posts: 38
    edited January 2013
    Thank you, I'll take a look at the "Spit"
    SDA CRS (2 tweets)
    SDA 1C Studios
    F1nut Posts: 50,753
    edited January 2013
    It's plastic, Windex works well.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited January 2013
    don't laugh this stuff is great it's not cheap
    http://www.eagleone.com/wax-as-u-dry
  • westmassguy
    westmassguy Posts: 6,850
    edited January 2013
    If there's wax build-up and embedded dirt, Fantastic or 409. If it's really filthy, Purple Power does the trick. Do a final cleaning with real Windex. After that, keep the wife and the Pledge away from them.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • bzpolksda
    bzpolksda Posts: 38
    edited January 2013
    PolkieMan wrote: »
    Thank you for your suggestions and help.
    I will post some before and after pics of the cleaning, I'm going to try to do this weekend:neutral:
    SDA CRS (2 tweets)
    SDA 1C Studios
  • thsmith
    edited January 2013
    WIndex and other suggestions will do a great job cleaning them.
    What I found was my black had started to go toward grey and looked dull.
    Pigspit gave it back a deep black luster. I guess that would be more restoring than cleaning.
