Sda 2.3
ken vilcins
ken vilcins Posts: 4
edited December 2012 in Troubleshooting
Just got my 2.3's out of storage and fired them up to find they shut down on high volume. They sound great at first then go into a mono sounding funk. Any technical advise to get started on trouble shooting. thanks
Post edited by ken vilcins on
    pitdogg2 Posts: 27,553
    Need more info to help
    amp? receiver? system in general.....
    shut down as in tweeters cut out?
  • ken vilcins
    I think its the tweeters. My system is fine, simple marantz. Sound is great then at high level starts to crackle and then shuts down to a mono muffle.
  • ken vilcins
    I think its the tweeters. There is a definite crackle in sound before they shut down. Sounds like an amp shut down but its not
    well with the limited info I'd say back her down a bit. Tweeters are poly switched so when it happens can you turn all the way down then turn back up and sound is back?
    If so then you are over driving your receiver ....
    my .02
    F1nut Posts: 52,150
    As pitdogg2 implies, you're not really helping us to help you.
    Please be more specific. What amp? What source, etc.?
    Please be more specific. Where on the volume control does this happen?
  • ken vilcins
    If I turn it all the way down after it happens and then back up it stays the same. I have to waite a minute and then go back up
