LSi 15 Rattle
eazyz
I just recently purchased (used) a pair of LSi 15's and I am experiencing a rattle at certain bass frequencys inside the right tower. Has anyone had this? Any thoughts on how I could fix it?
Post edited by eazyz on
remove the bass driver. Check to see if the spider (the corrugated part under the cone) detached from the frame. If it did, you can reattach it with crazy glue. Don't use the speaker for a few hours until the glue cures.
