SDA Binding Post Cups ?
gimpod
gimpod Posts: 1,793
edited January 2013 in DIY, Mods & Tweaks
I bought a Fully Assembled 800VA Dreadnaught in one of Larry's cases (Very nice cases, he
should autograph then :cool:) from nspindel so I need to redo the binding post cups for my 1C's,
remove the RCA connector I was using for the SDA cable and replace it with 2 posts. Now
seeing how I still have to do the binding posts for my 4.1TL project I decided to design a new
cup out of "Derlin" that can be used on both the 1C's and 4.1TL's, I got a quote for my design
and just about had a heart attack, The wanted over $700.00 for 4 cups and 29 days to make them
I don't think so!
Next step was to see how much it would cost to have 4 3 1/2" Dia x 1/4" thick plates with 5/16"
holes for the posts made like the following pictures.
2 of these for the 1C's
2 of these for the 4.1TL's
At $140.00 and 17 days again I don't think so! That's $35.00 a disk!!
Keep in mind that a 12" x 12" x 1/4" plate of "Derlin" cost about $25. Maybe I'm just being a
cheap SOB, I don't think so. What do you guys think.
BTW: I don't the tools needed to cleanly cut out the disks without leaving a hole in the center
like you would using a hole saw.
    VR3 Posts: 29,756
    edited December 2012
    I could probably get aluminum plates made for the SDA approximately $25.00 per plate if I could get a large enough commitment from you guys
  • Moose68Bash
    Moose68Bash Posts: 3,843
    VR3 wrote: »
    Would they be machined for the Neutrik speakON 2-pole connector for the SDA cable?
    F1nut Posts: 52,406
    Tony, eff all that just replace the stock IC socket with a Neutrik socket and terminate the cable with the matching connector. If you don't want to do it yourself, send them to me.
    VR3 Posts: 29,756
    It would be a neutrik
  • Moose68Bash
    Trey,
    Although this great guy in "NC" just finished redoing my stock binding post cups on the SDA SRSs and probably has already done the binding post cups on my 1Cs (:wink:), I would probably plump for the aluminum "upgraded" cups for both sets of speakers - ah, vanitas vanitatum!
    Would they look like the ones Toolfan66 designed for his speakers?
    VR3 Posts: 29,756
    It would be round, a drop in replacement to the stock SDA cup. No woodwork modification needed.
    I have thrown out the idea before -
    It would say "Polk Audio" in the classic font, +/-/SDA
    Brushed aluminum
    If I could have 10 pairs spoken for, I would do it for $25.00 each but I do not plan to "stock" these like my Fortress plates...
    If we can get 10 pairs sold, I can get the ball rolling and have a "product" in 3 weeks!
  • DollarDave
    DollarDave Posts: 2,575
    I'd be in for a set for a pair of 4.1TL's.
  • Moose68Bash
    Trey,
    Consider two pairs spoken for!
    VR3 Posts: 29,756
    We are getting there! :-D
    VR3 Posts: 29,756
    Also, this would be completely compatible with inductor mounted terminal cups - you would mount the plate with bolts, fasten it from the inside then thread the old terminal cup through on the inside, run the wires through, then bolt the old terminal cup down on the inside!
    It makes sense in my mind atleast!
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    Hey there Mr. Tray...If they fit SDA-SRS I'm in for 2 pairs. Mike
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • gimpod
    gimpod Posts: 1,793
    edited January 2013
    Not to put a damper on what Trey is offering but I think what Trey is talking about is a round flat 1/8" thick brushed aluminum plate with all the holes pre-driled, that would mean all the binding posts and the Neutrik NL2 connector out bast the back of the speaker, so if you ever have to transport the speakers on there backs which SDA's should be you'll have to remove that plate first.
    This is what I had in mind but at around $170.00 each I don't think so.
    Front View
    Back View
    Side View
    Isometric View
  • brgman
    brgman Posts: 2,859
    edited January 2013
    $170 each
    Um,Pass
    Happy Birthday again!
    I’M OFFENDED!!!!
    VR3 Posts: 29,756
    edited January 2013
    HBD Tony!
    No damper, sometimes we just have to be realistic! (That design would be nice, but wowzers) :-P A lot of modern day speakers utilize a plate with post sticking out... definitely would not have to remove it when in transit.
    VR3 Posts: 29,756
    edited January 2013
    I am sending the cup off Monday for measurements for the CNC!
    It is gonna be a real boy! :)
    F1nut Posts: 52,406
    edited January 2013
    Eh, I like the cup.
    Sure you would if transporting them on their backs otherwise some sort of provision to support the speaker so they don't rest on the binding post would be required. Even with the cups aftermarket posts stick out and the above cautions should be taken if placed on their backs.
  • headrott
    headrott Posts: 5,496
    edited January 2013
    I like the cup as well, but not enough to spend $170.00 for them. I would definately prefer a cup to a flat piece though.
    VR3 Posts: 29,756
    edited January 2013
    I will ask the CNC shop to price out a cup design for you knuckleheads! O_O
    VR3 Posts: 29,756
    edited January 2013
    To me $25-30 dollar to have a plate outfitted with the appropriate room for the NL2 and bi-wire binding post makes sense...
    Anything over the $40.00 mark would seem a little crazy to me...
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    I would honestly just rather have 1 set of binding posts and NL2 and thats it. No bi-wire.
    VR3 Posts: 29,756
    edited January 2013
    Hey Andre!
    What I may do, will talk to the CNC shop is like Tony did - have a point on the back that would allow someone (me probably, haha) to drill additional holes to accomodate different configurations :) (The point is so that it is straight)
  • gimpod
    gimpod Posts: 1,793
    edited January 2013
    VR3 wrote: »
    I hope you'll be sitting down when they give the quote.:eek:
    Toolfan66 wrote: »
    It's expensive to machine a part like this. Another thing change that angle going into the cup to just being 90 degree going in. That alone makes it easier to machine.
    I did it both ways and the price wasn't that much different. Go figure I guess most of the cost is in the set-up.
    Toolfan66 wrote: »
    Also you need to ask yourself what am I gaining by having a machined cup to what is already there? My purpose was to have more room between the binding posts. But not everyone wants to or has the know how to cut into their speakers the way I did mine..
    Not trying to keep this from happening but I could see the money going to trey for more worth while upgrades..
    I just wanted a drop in replacement cup with a deeper cup so the post wouldn't stick out past the back of the speaker. Access isn't an issue as I use Banana Plugs and I really didn't think it would run that much.
    VR3 wrote: »
    I agree, I can almost see $40 for a beefy cup setup the way I wanted it but then again it's just too much money, You can get the NL2 connectors and stick them in the stock cups for a set of speakers for a lot less then the cost of one cup.
