Subwoofer Hum
JCrew
JCrew Posts: 4
edited December 2012 in Troubleshooting
Hi. I'm new to this forum and found it by searching for replacement parts for my subwoofer.
Before I buy any new, and potentially unnecessary, parts I'd like to run my problem by the tech experts here.
I have a PSW202 sub that developed a "hum" whenever the power is on. I tried several wiring changes as well as a new shielded cable from the receiver to the sub. I also disconnected all of the speaker wires to the sub and the hum is still present. Finally, I moved the sub to a few different electrical outlets in the house, no other wires connected, and the hum is still there. If I press down lightly on the subs speaker the hum does diminish almost completely.
I should also mention that I have tried all settings on the back of the sub to no avail.
Any ideas? Do I need a replacement part or a new sub?
Post edited by JCrew on
  • PolkieMan
    PolkieMan Posts: 2,446
    Did it just start doing this or has it done it since it was purchased?
  • brgman
    brgman Posts: 2,859
    Try an orange cheater plug into the outlet.If it isn't better then maybe the Sw is bad.
    I’M OFFENDED!!!!
  • JCrew
    JCrew Posts: 4
    PolkieMan wrote: »
    The Sw is several years old. It started humming about a month ago and I had to take it out of use.
  • JCrew
    JCrew Posts: 4
    brgman wrote: »
    Not sure what you mean by "orange cheater plug".
  • brgman
    brgman Posts: 2,859
    the orange adapter you use to go from a 3 prong plug to 2
    if you don't have one you are un-American
    I’M OFFENDED!!!!
  • goofyGAguy
    goofyGAguy Posts: 545
    JCrew wrote: »
    My humble setup...
    ...is no more. :cry:
  • JCrew
    JCrew Posts: 4
    Although I have not tried the cheater plug I did use a heavy duty extension cord that accomplishes the same thing.
    The Sw uses a 2 prong polarized plug. All of my outlets are grounded. The Sw worked fine for 2 years before the hum started.
    Should I try and buy a new driver for the Sub or bite the bullet and just get a new Sw?
    Any other thoughts? Thanks.
  • gp4jesus
    gp4jesus Posts: 2,019
    PSW-202 is powered, right? If the hum is present regardless of settings and connections, or lack there of, it's not the driver. And that "cheater" won't fix hum in a device w/a 2 prong power connection.
    It's "sounds" like a PS issue. Maybe a failing PS cap or, more likely, a diode in bridge rectifier. A local repair tech should have little trouble fixing it for little $.
    Merry Christmas, Tony
    *all connected w/Premiere ICs
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello JCrew,
    In all likelihood there is a problem with the subwoofer's bass amplifier and it would need to be serviced. It would be best to contact Polk's CS department either by telephone at 1-800-377-7655 or via email at polkcs@polkaudio.com. If you can provide them with a date of purchase it will help them determine the best course of action to solve the problem.
    Regards, Ken
