technics sl-1200 mk ii...audiophile quality?
13»
  • Dawgfish
    Dawgfish Posts: 2,554
    edited January 2013
    Looking at their website, I would recommend the Ortofon Blue. Looks like you're running one on your Rega. How do you like it on your Rega? If you are familiar with cartridge setup and alignment, I would try mounting the Ortofon on your 1200 and see how it sounds. If you like it, buy one for your 1200 (or just leave the one you have now on your 1200 after you mounted and put the new one on your Rega).
  • Jhayman
    Jhayman Posts: 1,548
    edited January 2013
    Thanks Dawgfish..
    I was thinking the same. but wanting to try something different.
    I like 2M Blue on my Pro-Ject Table..but I can't mount it on the 1200 because I don't have a head shell yet..
    So no way to check it out..
    It's kind of hard to find TT stuff up here that stores have on hand with out having to order for you..
    Thanks for checking hopfully tomorrow they have a head shell and cart on hand..
  • jimsvm
    jimsvm Posts: 307
    edited January 2013
    Jhayman, can I pm you, thanks
    Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
  • Jhayman
    edited January 2013
    Sure you can, I just tried to PM you but you are Full..
    Toolfan66 Posts: 18,213
    edited January 2013
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2013
    Toolfan66 wrote: »
    Denon DL-160
    +1
    I run this same cart on my 1200MKII - very nice combo!
  • KellyMic
    KellyMic Posts: 166
    edited January 2013
    I use the Ortofon but looking for a new one now, will checkout the Denon.
    Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
    Crown D-75, Crown CE1000, Crown CE2000
  • wkjeffers
    wkjeffers Posts: 139
    edited January 2013
    the issue I see is at the used prices I find, you still have a used older Direct Drive table. old wiring, old electronics, etc.
    And you may not know if it was used as a DJ table in it's lifetime which would mean likely a little abuse and travel.
    I thought about one for a while, but would up giving a few hundred more for a NEW great sounding table from REGA with a warranty.
    SCompRacer Posts: 9,128
    edited January 2013
    Keiko wrote: »
    My DL160 is my backup now. .....
    Attachment not found.
    I likey the lighting in that pic. Nice pic Mike.
  • Jhayman
    edited February 2013
    Here's a little info from KABUSA incase you needed more info..Very Interesting Read
    http://www.kabusa.com/frameset.htm?/m1200.htm
    Click on Myths
  • allstock
    allstock Posts: 136
    allstock wrote: »
    I love mine and they do respond well to wiring/cable/isolation/platter/mat mods etc. I loved it more before I went to TTWeights open house yesterday though.... Having said that it's a very good bang-for-the -buck table and I think if you have a good one that hasn't been abused you won't lose any money, they have a HUGE following and I expect will for some time yet! If i was going to upgrade from mine I think I would go straight to a TTWeights unit, very impressed.
    Over the weekend installed a clearaudio Virtuoso Wood that I got for a good deal. It's still breaking in of course but has taken the table to a new level over the Ortofon 2m red.
    Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
    HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2)
    Keiko wrote: »
    ...........and am quite satisfied with what I have.
    That is all that matters......be happy! I like the Dynavector line too.
  • wkjeffers
    I talked t oa dealer in columbus that sold both rega and VPI. He said the rega RP3 was good for $1000 but if he was putting over that into a table, go with VPI
  • discokachina
    discokachina Posts: 1
    edited August 2013
    Keiko wrote: »
    My DL160 is my backup now. They're discontinued and may be difficult to find. Stretch it and go with this. Performs excellent on my SL-1210M5G. You'll thank me later. :wink:
    http://www.needledoctor.com/Dynavector-10X5-Cartridge
    I am thinking about the 10x5 for my SL1200 MKII.
    Would it be a good match for that model Technics as well?
    I am currently running an AT150MLK, do you think I will see enough of a difference between the 150 and the 10X5 to make the $450 investment worth while?
  • erniejade
    erniejade Posts: 6,321
    edited August 2013
    I think you will hear a difference but, whats the rest of your rig like? If your speakers, preamp, amp cover up sound or aren't revealing enough, then you might not.
  • newbie308
    newbie308 Posts: 812
    edited August 2013
    I love my SL1200 MKII! I've had it for more than ten years, and I've never had to replace a single belt! Ha Ha! I would not consider it "Audiophile" grade, but it leaves me wanting for nothing. Would I like to own a new VPI deck or one of those really cool skeletonized acrylic alien space ship turntables? Hell yeah, but I'll never part with my Technics.
  • erniejade
    edited August 2013
    The 1200 is still one of the few turntables you can set within 3 feet of a speaker and not get feedback. I know its up to the consumer to make sure a table is isolated but, technics did one heck of a job doing that work for us. Just make sure its level, on the fly vta, and make sure the car. is lined up right and your good to go for an easy deck. When I had a Linn, it didn't sound too much better for the money difference. Was there a difference in the sound, yes but not a 1000$ difference. When I had the linn I would could hear footsteps when walking across the floor ( till I got it on a more solid isolation) but, with the 1200, I never had to do that. Right now since my setup is in a small room, the 1200 is only 3 or 4 feet behind the Legacy Focus and they have a rear firing woofer! No hum.
