SurroundBAR 3000 mutes randomly
Trike117
As the title says, my SoundBAR 3000 stops playing randomly. I have to turn it off and on to get sound back.
The connections are fine. It's brand new. I bought it over Labor Day but just got the chance to install it tonight. It's only been in operation for about 5 hours. (I'm actually worried about that; being forced to wait so long to install it probably means I can't return it if it's defective.)
Is this a known issue and is there anything I can do? If there's no solution, what are my options for replacement?
Thanks,
Doug
Thanks,
Doug
Post edited by Trike117 on
Hello Trike,
Welcome to Polk's forum, I'm sorry you're having a problem. Have you used any external remote control to program the SurroundBar? If so, which one did you use?
Regards, Ken -
Hi Ken,
No, I haven't done any reprogramming at all.
Thanks,
Doug -
Hi Doug,
It is possible that the incoming signal is low enough that the SB's auto on/off function isn't kept in the "on" position. It might be best to contact Polk's CS department today at 1-800-377-7655 or send them an email to: polkcs@polkaudio.com. I'm sure they can be of help.
Cheers, Ken
