popping sub woofer
tlyoder57
tlyoder57 Posts: 1
edited November 2012 in Troubleshooting
Occasionally my sub woofer pops every several seconds. My guess is poor grounding. I usually fix it by turning off/on the sub-woofer. Is this a common problem with SB 3000 sub woofers that I'll just have to live with? Or did I purchase a rare, one-in-a-million defective unit?
Post edited by tlyoder57 on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    Welcome to Polk's forum. It is possible the popping is being caused by some other wireless device interfering with the wireless sub. Try setting the channel selector on both the SB3000 and the sub to a higher setting. Hopefully this will solve the problem. If it doesn't check with Polk's CS department at 1-800-377-7655 or via email at: polkcs@polkaudio.com
    Regards, Ken
