Lsifx
Fireman99
Fireman99 Posts: 129
edited November 2003 in Speakers
Ok im having troble getting a pair of fxi50's for my surround speakers (going to put the 30's in the rear.
My question is will the LSiFX blend in with the setup i have or not work well?
Dan
Recever AVR 8000
Amp PA 4000
CDR 26
Mains RTI 150 Bi wired
Center CSI 40 Bi wired
Surround FXI 30
Rear RTI 4
Sub PSW 140
  • afl
    afl Posts: 9
    I just got a pair of FXi50's from Crutchfield for $350 last week. They should still have some...
    AFL
    Mains: Polk RTi70's
    Center: Polk CSi40
    Surrounds: Polk FXi 50's
    Sub: SVS 20-39PCi
    Receiver: JVC RX-DV3SL
  • Steve@3dai
    Steve@3dai Posts: 983
    I can't see why they wouldn't blend.
    There isn't THAT much surround audio.
    LSi 9/C/FX
    Arcam AVR-200
  • mantis
    mantis Posts: 17,689
    Final answer is NO
    Dan
  • Frank Z
    Frank Z Posts: 5,860
    I'm going to say no as well, but will also tell you why.
    The RT line up are 8 ohm speakers, the Lsi are 4 ohm speakers. That could cause you some problems right off the bat.
    Second is that the Lsi series use Vifa Ring Radiator Tweeters, your Rt seies do not. They are in no way, shape, or form timbre matched. Yes it does make a difference, but how much is debatable. My opinion is that for the best possible sound, use matching speakers. Rt with Rt, Lsi with Lsi.
    Hope this helps.
  • Fireman99
    Thank-you Frank I was looking into the 4ohm deal to see if that was a problem. And I wasnt sure about the Tweeter how much it would be diffrent since I have not been able to listen to any LSI speakers =(.
    Living in Canada I think the online retailers are out for me I'll end up paying 3x the cost with shipping and duty brokerage fees etc. and I picked up my FXI30's for $250 cdn just cant find a pair of 50s.
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • Frank Z
    Dan,
    Have you considered putting the 30's on the sides and using a pair of direct radiating speakers on the rear wall? A pair of 28's would work very well for rear channel duty, and they would probably cost less thana pair of 50's.
  • Fireman99
    Thanx again frank I'm going over to take a look and listen to the 28's and 38's today and see if they will do the job sounds like a good opiton though.
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
