Ulv
katya
katya Posts: 32
edited November 2003 in Troubleshooting
Ultra Low Viscosity (ULV) Magnetic Fluid
Polk discovered this Fluid to cool the SL3000's voice coil. The result vastly increased its performance and reliabilty flatness of response, phase linearity and power handling, extend frequency response, free peaks to beyond 26khz.
My question is: is it possible to order this Magnetic fluid
to Polk? And if yes, how much is the amount to replace the old fluid in the SL3000's? any thoughts about this.
Because they are already more than ten years old I think I should oil change my SL3000's Magnetic Fluids...
Katya
My Polk Audio Speakers are:
RTA 11TL>SOLD
CS 245i
LS/Fx
PSW 650
Post edited by katya on
  • dorokusai
    dorokusai Posts: 25,576
    One word, impossible. No it is not available from Polk, and the fluid is not replaceable.
    The SL3000 is doomed to become completely extinct at some point. Unless you have some backups, I would start thinking of the new replacement that is available. You will eventually go insane trying to find SL3000's....especially ones that Har Navalta hasn't allready bought :D
  • katya
    katya Posts: 32
    They are easy to change the Fluids as long as the Fluid are available and must know how much amount.
    All Fluids can be replaced no matter what kind of this things are.
    Katya
    RTA 11TL>SOLD
    CS 245i
    LS/Fx
    PSW 650
  • RuSsMaN
    RuSsMaN Posts: 17,985
    What do you know about the fluid and its properties that would cause it to 'wear out' and need changing?
  • dorokusai
    Katya - I would love to see that happen, good luck
    If its that easy to change you should have a shootout between, Polk Audio UVL and Quaker State 10w30. :rolleyes:
    F1nut Posts: 51,997
    The fluid is no longer available at any price, hence the reason Polk no longer offers the SL3000 as a replacement. Besides that little problem and as others have stated, you can't change it anyway.
  • katya
    katya Posts: 32
    What do you mean no longer available at any price, maybe at Polk
    but not somewhere else also you said I cannot change it?
    I can change mine not yours...
    Check this link:
    http://www.ferrotec-europe.de/en_uk/htmls/audio_fluid_technical_information.php
    Katya
    RTA 11TL>SOLD
    CS 245i
    LS/Fx
    PSW 650
  • RuSsMaN
    Looks like you answered your own question genius, change away.
    Check this link when you are done, and report back.
    www.hop.com
  • HBombToo
    HBombToo Posts: 5,256
    www.hop.com
    Thanks for the link Russman!!! I have been looking for that after being told I'm an idiot and can't spell:D
    HBomb
    ***WAREMTAE***
  • dorokusai
    Another SL3000 on its way to the cemetary. :D
    F1nut Posts: 51,997
    Well, wtf do I know anyway.........Polk told me that they can't get the fluid anymore. As for changing it.......let me know if you do, I'd like to know how that works out.
  • Tour2ma
    Tour2ma Posts: 10,177
    geez... only 12 variables ought to be a cinch finding the replacement...
    then again i can't even find the drain plug on my spare 2000's... :D
    More later,
    Tour...
    Vox Copuli
  • katya
    katya Posts: 32
    I am serious about changing my SL3000's Fluids I will let you know once it is complete.
    Hey Tour2ma, you have to open your SL2000 and wipe the old
    fluids by cotton buds simple...
    Katya
    RTA 11TL>SOLD
    CS 245i
    LS/Fx
    PSW 650
  • hoosier21
    hoosier21 Posts: 4,420
    please explain how to open up a tweeter?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • har_navalta
    har_navalta Posts: 957
    Answered by Polk Engineering
    Original Message
    From: Harry Navalta [mailto:harry.navalta@bharchitects.com]
    Sent: Friday, November 14, 2003 12:35 PM
    To: 'Swauger, Ken'
    Subject: SL3000
    Hello Ken,
    It happens that one Club member open this topic and I am interested to find the answers too, about the Ultra Low Viscosity (ULV) Magnetic Fluid for the SL3000.
    I would like to ask you this question also.
    What is the equivalent Magnetic Fluid that you can buy in the stores and also how much amount of fluid to drops in every tweeter if there is limit.
    Regards,
    Harry Navalta
    Original Message
    Sent: Friday, November 14, 2003 2:01 PM
    To: 'harry.navalta@bharchitects.com'
    Subject: RE: SL3000
    Hello Harry,
    Your question is forwarded to the Engineering Department
    Regards,
    Ken, Polk
    Original Message
    Sent: Friday, November 14, 2003 12:41 PM
    To: Lumsden, Stu
    Subject: FW: SL3000
    Stu,
    Can you offer an opinion on this?
    Thanks, Ken
    Original Message
    Sent: Friday, November 14, 2003 1:55 PM
    To: Swauger, Ken
    Subject: RE: SL3000
    An equvalent magenetic fluid is probably best found through Ferro Fluidics http://www.ferrofluidics.com/. They have offices all over the world. They can help directyou to a suitable replacement but it would be best to use one of their products.
    Gauss: as high as available is best
    Viscosity: 100 - 500 cps
    Ammount: When the gap is filled with only about 3/16" of circular arc left unfilled that should be about right.
    The amount was measured in microleters. I could look up the exact amount but most people will not have the means to dispense it. It would be easier for a layperson to use a dropper or syringe and just hold it near the magnetic gap of the tweeter. The magnatism of the gap will draw the fluid out of the syringe so pay attention to your work. If you overfill then use a napkin or tissue to wick the fluid out of the gap. No other means of extraction will work as well because of the magnetic attraction.
    Good luck,
    Stu Lumsden
    VP of Engineering, Polk Audio, Inc.
    5601 Metro Drive, Baltimore, MD 21215
    tel: 410-764-5221, fax: 410-764-5491
    I will try myself to change some of my SL3000 old Fluids too.
    Har
  • dorokusai
    Good luck Dr. Polkenstein's, let us know the attrition rate of such a project.
    F1nut Posts: 51,997
    Very interesting! If one of you do it, let me know how it goes.
  • katya
    katya Posts: 32
    hmmm...interesting
    RTA 11TL>SOLD
    CS 245i
    LS/Fx
    PSW 650
    F1nut Posts: 51,997
    Katya,
    Just for the record, I'm dead serious. I have opened up the SL3000.......actually 4 of them. When I spoke with Ken about it, he said he wouldn't advise it...oh well, too late. Have you actually opened one up yet? If not, I'd be glad to share what I know.
    If you want to help, believe me it's welcome, but what's with the attitude??? You question why I want more spares when I have 4 (actually 2 working) spares and then you post that you have 5, WTF??? And you never did answer my PM.
    F1
  • Tour2ma
    Originally posted by katya
    most of the people here are only fooling around...
    guilty as charged...
    pleasantly surprised that cs is giving fluid selection guidance, albeit on only two criteria (so far)...
    as for disassembling tweeters... not a skill i've been forced to acquire as yet... guess the old 2000's are made of sterner stuff.
    good luck all. look forward to reading of your progress.
    More later,
    Tour...
    Vox Copuli
  • har_navalta
    Hello Katya, that's nice of you to part one SL3000. I love to have one but I have also one spare and one that doesn't work but since you mentioned that you have 5, I am happy to have it, email me here: har_navalta@hotmail.com and we can talk from there.
    Har
  • katya
    katya Posts: 32
    F1, I know you want also to change your SL3000 fluids. I will let you know the outcome. I questioned you because you have already 3 spares right? how come you want for more?
    Katya
    RTA 11TL>SOLD
    CS 245i
    LS/Fx
    PSW 650
    F1nut Posts: 51,997
    Kayta,
    Ok, sounds good, let me know.
    I only have 2 working spares. I want more because you never know when you'll need them...simple. More is better.
  • katya
    katya Posts: 32
    f1 thinks that I am the alter of that guy...hmmm
    RTA 11TL>SOLD
    CS 245i
    LS/Fx
    PSW 650
    F1nut Posts: 51,997
    Does anyone else here think that Katya is Har's alter ego???
  • Tour2ma
    lol...
    More later,
    Tour...
    Vox Copuli
  • katya
    katya Posts: 32
    f1, you don't have any idea who am I...
    RTA 11TL>SOLD
    CS 245i
    LS/Fx
    PSW 650
  • RuSsMaN
    F1, now that you mention it, yeah.
    F1nut Posts: 51,997
    Maybe this will help.........
  • Tour2ma
    OMG... not another twin...
    More later,
    Tour...
    Vox Copuli
  • HBombToo
    Huh:confused: was there a party and I was not invited;)
    Tonight will be a good night:p
    HBomb
    ***WAREMTAE***
