Power cord theory - I know - over hashed - but what if...
ALL212
ALL212 Posts: 1,577
edited November 2012 in 2 Channel Audio
A strange set of circumstances have led me to rethink the power cord magic. The odd thing is that some people swear by a particular cable as it makes major differences and some, even after having tried good cables, don't seem to hear a difference. I have been in the "cover my butt" corner and refuse to use stock cables but I do use upgraded cables - not having noticed a difference between them. The straight logic is that it's a wire - if it's big enough to supply the current needed then it's done.
After reading an article and also having a discussion with a very learned person today I'm going to pitch this and see how many stones come zinging my way.
I think my theory goes like this: It's not so much that the power cable actually makes an amp sound better but that the power cable masks poor power supply design or poor building wiring.
I'm still trying to piece this all together so don't go writing a bible yet. :rolleyes:
Power supply's have resistors, caps, inductors...all that electronic stuff that makes the magic. But each of those components also has other electronic characteristics. Caps have a resistive value, resistors can have a capacitive value, inductors have a resistive value - on and on. These values are very small and are not normally figured into the design of the overall unit. What if these other values are creating their own circuits and creating noise? This noise would be reflected in all the circuitry it connects to. This noise might not even be initially audible but could potentially cause components to not perform exactly as expected.
Say the unit has this issue - combine it with poor house wiring (of any flavor - I'll expound further later...) and a stock power cable. If you replace the stock power cable with a well shielded one that is put together well with good components it's possible that some of the "effects" of this combination could be lessened. We might percieve this as a problem in the original cord or in the house wiring but in actuality it's from the unit itself.
I'm not an electrician, nor an electrical engineer - so my "expertise" should be in question - I'm just pitching a theory here.
House wiring - two sides of a breaker box. Some fuses on the left side...some on the right. These fuses (opposing) would be on different legs of your inbound power. If you have one side of the room on a "left" breaker and the other side on a "right" breaker will you have the same exact ground potential? Would it be better to feed your room from breakers all on the same side of the breaker box?
Poor power supply design combined with not perfect house wiring combined with a stock, unshielded power cord = a different sound?
Aaron
Enabler Extraordinaire
Post edited by ALL212 on
    mhardy6647 Posts: 34,049
    Most good resistors are noninductive and should also exhibit no - or at least negligible - capacitance.
    The DCR of an inductor (choke) is an important parameter when large(r) value inductors are used in power supplies - and crossovers and is factored into the circuit's design.
  • BlueFox
    BlueFox Posts: 15,251
  • Face
    Face Posts: 14,340
  • sucks2beme
    sucks2beme Posts: 5,614
    I believe that a good dedicated 20 amp home run to the breaker box should be 1st priority. Then try the power cord.
  • ALL212
    ALL212 Posts: 1,577
    Face wrote: »
    I didn't mean to start a buying spree but I like the thought of these and they aren't priced too bad. Face - you using these? How stiff are they?
    Aaron
  • dkg999
    dkg999 Posts: 5,647
    The main advantage of upgrading your power cable is that it looks very cool. If it looks cool it must sound better. All of your sensory devices work together in a conspiracy. It's kind of like women, if they look hot and smell good then your brain ignores their wicked nasty personality.
    DKG999
  • DarqueKnight
    DarqueKnight Posts: 6,765
    ALL212 wrote: »
    Electrical codes and power company vary from place to place, so what works in one location might not work, or might be detrimental, in another.
    The monoblock power amps in my two channel system are on different dedicated 20 amp circuits, each of which is on a different leg. There is a third 20 amp circuit which feeds the source components and preamps. I don't have any issues with ground loops.
    My home theater system is fed by two dedicated 20 amp circuits, each on a different leg. Again, no issues with ground loops.
  • Face
    Face Posts: 14,340
    ALL212 wrote: »
    Yes, I use their Aurora cables throughout my rigs. They're very flexible.
  • rpf65
    rpf65 Posts: 2,127
    Me, being the novice that I am, I would probably worry about the wiring and outlets to whatever cable that you may like, before worrying about the power supply cable. I could be wrong here, but I'm fairly sure that each and every reciever/amp/sub/etc has a transformer really close to the output of that power cable.
    The transformer, by it's very nature, isolates the circuitry from the line voltage. Sure, transients, spikes etc... can be transferred through the magnetic field. I would probably try a good quality power conditioner before multiple cables first.
  • drumminman
    drumminman Posts: 3,396
    dkg999 wrote: »
    Simply not true in my experience. I've even heard improvement on my equipment that resolves at an "average" level. The materials, geometry of the wire and quality of the connectors all play a role.
    I recently upgraded the connectors on a DIY PC I've used for years from a marinco IEC/wattgate AC plug to Furutech Gold. While the improvement was not overly dramatic it was detectable without too much effort.
    Not trying to start a cable debate, but you should play around with some different designs.
  • RamZet
    RamZet Posts: 792
    buy a nice power conditioner and be done with it. Like this one http://www.amazon.com/Panamax-M4300-PM-Outlet-Clean-Power/dp/B000SXWGDI/ref=sr_1_1?ie=UTF8&qid=1352648246&sr=8-1&keywords=panamax+m4300
    Its the Panamax 4300. You can get it new on AMAZON for 180 (they just put out a newer version so the 4300 is cheap now.)
    I cant tell you how many of these I have installed, maybe 200 and more then 100. They clean up all the nasty sounds coming from our third world power from LIPA here on Long Island. A must have.
    B&W CM9Classé Sigma
