MW Driver specs
cwsmith68
cwsmith68 Posts: 434
edited November 2012 in Vintage Speakers
I have searched and searched for this. I would almost bet that I had come across a list of most of the older MW (6500,6503,6511,6600 etc)
specs on here before , all in one place. Did I dream that up or what? I would really appreciate anyone that could point me in the right direction.
Thanks,
Coley
Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
Post edited by cwsmith68 on
  • gimpod
    gimpod Posts: 1,793
    pitdogg2 Posts: 26,959
    i wish that was a sticky. Do not know how much time i have invested to find it from time to time......lots:)
  • dorokusai
    dorokusai Posts: 25,576
    Sticky.
    It's been moved to vintage speakers for parity.....fast enough for you PitDogg?
    Mark
  • Mystery
    Mystery Posts: 2,546
    So, just by DC resistance, it's not a guarantee to confirm a MW model as I see three models with close readings and depending upon a MM, it may suggest either one of them.
    Hmm... so if I just have a MW driver with no model information, it's kinda tricky to tell what it is.
    3 MW 6501 1.47 5.96 N 3.25 E - 3N/M 7.75 Ohms 31 Hertz
    5 MW 6503 1.82 5.24 N 3.55 E - 3N/M 6.54 Ohms 29 Hertz
    6 MW 6509 2.1 4.57 N 3.54 E - 3N/M 8.97 Ohms 30 Hertz
    7 MW 6510 1.39 6.32 N 3.41 E - 3N/M 6.57 Ohms 31 Hertz
  • dorokusai
    Mystery wrote: »
    What speaker do you own? Most of the schematics have been posted and it should be fairly easy to narrow the selection down for your particular loudspeaker.
    dorokusai wrote: »
    Sticky.
    Mark
    your the man quicksdraw:)
    thanks Mark
  • Mystery
    dorokusai wrote: »
    Well, I have a thread here on identifying two MW drivers that I have and no idea what they came off of.
    http://www.polkaudio.com/forums/showthread.php?136536-Polk-6.5-inch-driver-ID-please-SR-142-17
    Multimeter reads 7.7 ohms and another consistent at 7.6 ohms and the consensus was they are MW6501.
    However, assuming my Harborfreight multimeter readings are little off, they could be any one from those 4 I mentioned above as they are all within 1 ohm range from my readings. :exclaim:
  • skrol
    skrol Posts: 3,437
    In that range the HF multimeter is crap. When I reworked my crossovers, the 1.5 ohm 1% resistor measured 4.8 ohms with my HF meter and 1.51 ohms with my calibrated Fluke 187. Which do I trust?
    Your driver is a little unique in the shape of the dust cap. I am trying to remember which ones had that style, though there may not be too much rhyme or reason. I'll check when I get home tonight.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • dorokusai
    Mystery wrote: »
    Well in that case you're proper forked since the origin is loose. VOM readings are not indicitive of a specific driver in reality and if the consensus was MW6501, I'd defer to that driver.
    They are all close in specs and close enough for you to never know the difference audibly from my perspective. Go with your gut and I'd choose the MW6501.
    Mark
  • cwsmith68
    I don't see the 6600X. Any idea?
    Main system:
  • Shacky
    Shacky Posts: 113
    How about 6500?
