What to buy?
I am considering buying new RtiA9 or rtiA7 speakers. I have Onkyo 135 w AVR . I have read reviews and forums and most say you need HUGE amplifier power to run these. Due to budget I cannot afford a big amp right now! Will my
AVR be able to handle these speakers or what is alternative. I want to upgrade to a 5.1 surround system with matching surrounds and center. Any suggestions !
You'll get varying opinions here, but that sounds like one of the beefier AVRs from Onkyo - 800 series? I'd say it should run the RTiA7s nicely, and the A9s adequately. Obviously, additional separate amplification would improve things, but that receiver should be capable. Capable enough? That's for you to decide.
Welcome to Club Polk!! -
The avr will play the speakers. Just depends on what u r expecting. For a few hundo u can pick up a vintage amp ie ( parasound B&K adcom ect.) and get far ( and i mean far) better results. I am assuming u want real good 2 CH SOUND out of it, use the avr for HT.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
why not A5? They will sound better than A7. Given that u have a good sub, of course.
My opinion is that trying to get bass out of towers is a huge waste of money. I am not recommending A5s so u save money. I do because they will sound better. A5s + good sub > of A9 powered by the best amplifiersI have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.
jeremymarcinko wrote: »But as in all things your perception is your reality. -
mdaudioguy wrote: »You'll get varying opinions here, but that sounds like one of the beefier AVRs from Onkyo - 800 series? I'd say it should run the RTiA7s nicely, and the A9s adequately. Obviously, additional separate amplification would improve things, but that receiver should be capable. Capable enough? That's for you to decide.
These days, if you want a beefier AVR from Onkyo, they're forcing you into their upper end 3XXX and 5XXX receivers! The lower models, including the new 1010 (which isn't bad; draws 1 amp less than my old-time 805 which draws 9.5 amps from your wall, whereas the 1010 has more channels and only draws 8.5?).
The 818 draws 8.1 amps and weighs only 40.3 lbs compared to the 50.9 lbs of the years old 805?? Of course these new AVRs have tons more features, it's their amp sections that are "less capable". If you have the money and you want a "powerful" Onkyo go for the models above! 55 lbs and 11 amps (they are configured for 9 channel + 2--extra amperage needed--the 805 is a simpler 7.1). If you plan to use external amplification, the 818 is all you would ever need!
A5s sound better than A9s with subs? OK, to each his own. Maybe one should call up the Polk engineers and tell them they got the A9 design all wrong?
I guess all that time they spent in R&D was a waste!
A little more info could help,like what model of avr is it?samsung un40eh5300
yamaha rx-a3010
oppo bdp-105
rtiA7, front
csiA4, center
rtiA1, front presence
rtiA1, surrounds
PSW 505, sub -
I would go with the 7's or 9's with your AVR then plan to add an amp later on down the road when funds allow. Just make sure your AVR has analog pre outs so you can hook one up.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
My AVR is Onkyo Tx NR809 I've got fairly larger living room area 23' wide X 24' deep. So can use bigger speakers!
So....are you or are you not recommending A5's? Getting bass out of towers is a waste? You should listen to more towers then! I loved your "best amplifiers" comment! :rolleyes:--Gary--
Ok, now I have to figure out how to block quotes from this r guy! :rolleyes: Anyway, Your AVR will run the 7's just fine but with that size room you might want to add an amp with the 9's.Anaheim Hills CA,
HT 5.1: Denon X3900H/ BDP-Denon DBT1713UD / Polkaudio LSiM703 / W4S mAmp's / Polkaudio LSiM706c / Polkaudio LSiM702F/X's / SVS SB2000 Pro / Panasonic TC P55VT30
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Welcome to the club!
You have a solid receiver, so you will be able to drive the A7's without any problems. The A9's might require a bit more power due to the number of drivers on these towers. However the good news is that your receiver has preouts and therefore you are golden. I mean, you should be able to add an external amplifier whenever you want or your budget allows.
I personally did that, drove my A9's for several weeks just using my receiver (Yamaha) and during that time I was looking for a good second hand amplifier. So, if you are not in a rush, you can try to do that.
Good luck with that, have fun and report back! -
If your anywhere near New York, I can hook my A7 back up for you to listen...
Hell you can even buy them from me!
I drove mine off of my Denon for years with zero complaint. The A9's I would not bother with untill you have a separate amp, personally. -
Welcome to Club Polk.
I really like my A9's and they are as good as you can get in a tower speaker, any brand, for the price. YOU WILL NOT APPRECIATE THEM UNTIL YOU POWER THEM, and no AVR on earth can do that. I have powered mine with an old HCA 2200 Parasound and that does the job however they could still stand some more.
A9's also do something very well: they LOOK GREAT and that is very important to me.
Along with the A9's I also use a 2pair of RTI A3's and a pair of RTI A1's in different systems. They all sound terrific on their own and look stunning and are easy to place. These little guys when paired with powered subs could make a very nice HT system which will run on just about any mid-grade AVR and used later in an office or book-room as you learn more about what a real HT set-up looks like. My current HT is a pair of SDA-SRS in the front with 2 micro-pro subs, a pair of 2000p's with powered subs in the rear and some old 28's on side duty with a RTI 6 as center. the only things changed out in this system for the last year is the center and that will probably change quite soon as I cannot seem to get enough dialog from the 6.
So to your original question of RTI A7's or A9's: neither. Go a little smaller to the A-1's or A-3's, a nice sub and you can enjoy good HT and very good 2-channel with your 135WPC Onk. Participate with this forum read everything you can and learn.
Sound is fun, enjoy your new passion and realize it is never over and always changing.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
I'll chime in w/Michael. A pair of 'A3s w/the sub of your choice. Later move them to the sides or back when you $ettle on A7s or 9s w/a robust* amp.
* 4 ohm stable
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Heck, I say A9's all day. They have a better midrange than the sibling A7. I've got the Onk 807 and although I don't power my A9's with my receiver, I wouldn't think they are going to sound "bad" by doing so. And, you can look at it this way, you've got the A9's now, you listen to them powered by your 809, down the road when you can afford to add an external amp (highly recommended), it will be like getting a new pair of speakers, some bad a** speaker for the price of an amp.
Emotiva amps are not the most popular brand on this forum, but they are less expensive than a lot of other brand name amps, and they do put out extra power over your AVR. I've got two of them and my A9's sound really great. It's a less expensive way of getting the much needed power to your speakers.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
i don't understand why everyone is stubborn about using precious power from a power strainer receiver for feeding woofers on a tower, that will NEVER move air like a 12" sub. If you do have a good sub (1) and your only power source will be the AVR (2) it is really stupid to go A7 or A9. Get A5s or A3s, and your receiver will be perfect and will supply optimal power for the speakers, and the sub will take care of the rest.I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.
Well all of you convinced me not to buy RTIA9 or a7 thx! Buying another brand!
Get emotiva xpa3 that will be more than enough to drive your rtia9Front: Tekton Pendragon
Center: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2 -
That's a shame, they're great speakers. What are you going to go with instead? -
I agree with emotiva for budget price or look at an entry level Parasound, some have John Curl designs. Good value.
to michael1947 coment I agree not to shaby at all.ht rm.:loneranger:
arcam rblink
tyler acoustics d4mx frt.
csi a4 polk audio ctr.
fxi 3 polk audio bck
dsw 550 wi polk audio sub
sony 3600 es
adcom gfa 7605
sony bdp s-270
sony 40 lcd wide screen
panamax m4300
game:redface:
32 in. samsung
sony dhs810
m10 polk audio
Polk audio rti a1
zone 2:eek:
bose 601
advent 6003 -
My bet is on Klipsch.HT SYSTEM-
lsi 9's -
I'm buying some Martin Logan Motion 40 mains , Motion 30 center, Martin Logan sub, Martin Logan surround sides, really nice sounding speakers !
