POLK AUDIO SURROUND BAR 3000 Lost Remote
cnix
I lost my soundbar 3000 remote in the process of moving. Not really a problem in terms of volume control since I can reprogram my tv remote. However, I can't seem to find a way to control the subwoofer levels without the original remote.
Is is possible to buy a replacement remote for my unit? If not, is there something I can do to control subwoofer levels?
Thanks for any input or suggestions.
Post edited by cnix on
While the bar is on and playing, tap "learn" on the bar one time. This will put the bar in the subwoofer level adjustment mode. Then use the volume "up" or "down" arrows to obtain the desired level. Once set, leave it alone, do not touch any of the functions on the control panel and and it will time out of this function about 20 seconds after you have made your final adjustment.
Hope this helps.
Thanks for your reply. I was able to successfully turn up the levels on my subwoofer. I was wondering if I have to wait for it to time out each time? The light in the middle turns yellow when I am adjusting the subs but it doesnt turn back to green for a long time, unless I press the learn button again.
