RTA 11T's , a few questions.
ipsullivan
ipsullivan Posts: 65
edited November 2012 in Vintage Speakers
I am relatively new to the vintage and audiophile game. I purchased a pair of RTA 11T's several months ago, more or less based on a whim due to them being available locally and a little bit of research. I am still happy with my purchase they are great towers.
They are currently being powered by a Yamaha M-65 amp and C-60 pre-amp. The amp could use a restoration but still performs.
Questions:
What can be done to upgrade the speakers with out spending too much money?
Upon further inspection and a rattling from one of the PRs what seems to be a diaphragm is torn and detached from the rear of the cone in spots. Anyway to repair this? I was thinking some sort of epoxy but needs to be flexible. I plan on getting a new PR when I can find the right one. What causes this? I am thinking just age, wear and tear.
The PRs seem to max out with a few songs that have deep bass unless I reduce the bass levels on the pre-amp. Sounds like the cone/diaphragm is hitting the rear of the PR's frame. Any solution to this other than turn the volume down?
Could I benefit from wiring these differently from the amp? I am currently using double wire for them it is marked CSA TYPE PCC FT4. The guy I bought the amp and pre-amp from said it would work well. What is recommended for a setup like this?
Any help would be much appreciated here.
Thanks,
Ian
A little eye candy:
Post edited by ipsullivan on
  • skrol
    skrol Posts: 3,393
    edited October 2012
    Welcome to Club Polk. I agree, I really enjoy my RTA11TL's especially after the upgrades.
    For upgrades, Polk came out with a tweeter upgrade to your SL-2000 tweeters. It is the RDO-194 which can be purchased through the Polk Audio parts department. Tell them that you are a Club Polk member to get a very nice discount. Next, consider upgrading crossover capacitors and resistors. I can recommend Clarity Caps or Sonicaps for the capacitors especially in the tweeter circuit. You can economize and go with Jantzen (Parts Express) for the mid-woofer circuits. Mils or Mundorf are good for the resistors. You can apply Dynamat (or similar product) to the baskets of the Mid-woofers and PRs to eliminate ringing.
    On your PR when you say diaphragm, do you mean the spider spring? I have seen these detach from the basket and was able to re-attach using epoxy. If it is detached from the cone, something flexible like a silicone based adhesive may work. Post a pic if you can.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • brgman
    brgman Posts: 2,859
    edited October 2012
    I second what skrol said and may also mention that if you are pushing the amp too hard the speakers will get the bad end of the deal.aka distortion and ultimately damage.
    I’M OFFENDED!!!!
  • westmassguy
    westmassguy Posts: 6,850
    edited October 2012
    skrol wrote: »
    Actually you don't need any real specialty glue there. Aleen's Tacky Glue, available just about everywhere, will work just fine for both repairs. It's a Ketone modified white glue, which bonds with just about everything. Use a small artists bush to apply it where the separation is. If the rubber surround is detached, then a specialty glue would be required for that.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • ipsullivan
    edited October 2012
    skrol wrote: »
    Yes I believe it is the spider spring. It has a partial tear as well as being detached. I am going to pick up some epoxy, how far on the spider spring should I apply the epoxy to? I was thinking about a 1/4".
    As for crossovers, what kind of improvements will I see if I upgrade them?
    Thanks,
    Ian
  • ipsullivan
    edited October 2012
    Is there entire crossover that I can purchase to swap with the originals?
    F1nut Posts: 50,753
    edited October 2012
    Do not use epoxy to repair the PR spider. Westmassguy suggested the proper glue.
    Well yeah! With a damaged PR that is going to happen.
    Define too much money. While you're thinking about that, a search here will turn up all kinds of ideas for mods.
    No idea what that is. Is it actually speaker cable?
    Mo' better sound.
    No.
  • trav0810
    trav0810 Posts: 1,056
    edited October 2012
    are you using Data cable for speaker wire? I have seen that rating on ethernet cables.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
  • rdozz
    rdozz Posts: 24
    edited October 2012
    I see the PRs pop-up on ebay sometimes, which PR is the problem? I was experiencing some distortion with my 11ts. It turned out to be the amp I using could not handle pushing the speakers. The distortion really showed up in the bass responce. The amp you are using is probablly not the problem but it could be the PR if it is broken? I have been able to rebuild my RTA 12s and RTA 11ts cheaply by watching ebay and the help this site has given me. Good luck, they are sweet speakers when they are working properly.
  • ipsullivan
    edited October 2012
    rdozz wrote: »
    The upper PRs with both do it with extreme bass and high volume levels. Only one is damaged though. 95% of the music I put through it wont do it.
  • hewlew1
    hewlew1 Posts: 154
    edited October 2012
    PR's for this model come up on ebay now and then just enter Polk passive radiator.
  • skrol
    skrol Posts: 3,393
    edited October 2012
    Some things to note when sourcing the replacement PR... You likely already noticed that the upper and lower PRs are different. Also make sure that they are for the RTA11T and not the RTA11TL. I believe that they are tuned differently.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,393
    edited October 2012
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ken brydson
    ken brydson Posts: 8,783
