Is it normal for brand new drivers to distort?
nspindel
nspindel Posts: 5,343
edited October 2012 in Vintage Speakers
Had a problem with one of the 6511's in the new 4.1TL's, so I ordered a new replacement from Polk and just installed it. It sounds very distorted. Is it normal that a brand new driver will sound very distorted while it's breaking in. It has a very "buzzy" sound in the bass. To be expected? Or is something wrong with the driver?
Post edited by nspindel on
    treitz3 Posts: 19,215
    edited October 2012
    It sounds like something is wrong with the driver, nspindel. Is that all you swapped out? If the new driver has the same issue as the old driver, you may have an issue upstream.
  • nspindel
    edited October 2012
    Yup.
  • halo71
    halo71 Posts: 4,606
    edited October 2012
    Yup as in that is all you swapped out or as in same issue as the old driver? Have you checked to see if the spider may have come loose from the cone?
    --Gary--
  • nspindel
    edited October 2012
    All I swapped out was the driver. This is a brand new replacement driver straight from Polk, so it would have 0 hours on it. Haven't checked anything yet. My plan is to first just give it some hours and see if it settles in on it's own. Next up I'd swap it to the other speaker to see if the distortion changes sides. If it does then I know it's the driver and nothing else. If not, then I've got something else wrong.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited October 2012
    The speaker can be hooked up direct as long as you don't get crazy with it.
  • nspindel
    edited October 2012
    Huh?
  • halo71
    halo71 Posts: 4,606
    edited October 2012
    He is talking about bypassing the XO to ensure its the driver and not something wrong with the XO.
    --Gary--
  • nspindel
    edited October 2012
    Bad driver. It's sticking when I press it in, magnet must have shifted in shipping. I'll call Helen tomorrow.
  • Mystery
    Mystery Posts: 2,546
    edited October 2012
    nspindel wrote: »
    I thought they fixed that on new drivers. :question:
  • PolkieMan
    edited October 2012
    Yea hook it up direct, wire to source.:biggrin:
    They sent me a MM6510 instead of a MW6510. Mistakes happen.
    nspindel wrote: »
  • nspindel
    edited October 2012
    Mystery wrote: »
    Maybe it didn't shift during shipping, maybe it's just a bad unit. But it's definitely rubbing substantially when you hand-move the driver.
  • Mystery
    edited October 2012
    nspindel wrote: »
    Maybe it's defective unit but just be careful on hand-move test.
    Even perfect drivers rub when pressing with hand due to not being straight down.
  • nspindel
    edited October 2012
    Nah, this one's definitely bad.
  • inspiredsports
    inspiredsports Posts: 5,501
    edited October 2012
    Back to post #1 (assuming upstream is known-good), my opinion is that if a new driver anywhere, anytime, any brand ever distorts, it's a bad driver.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Schurkey
    Schurkey Posts: 2,104
    edited October 2012
    ...provided it's not being over-driven, or driven beyond it's frequency limits.
  • skrol
    skrol Posts: 3,393
    edited October 2012
    Sounds like a bad driver. It happens to the best of companies. As an old Japanese friend told me, "Sometime monkey fall out of tree."
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • westmassguy
    westmassguy Posts: 6,850
    edited October 2012
    skrol wrote: »
    LOL too funny
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • drgalexo
    drgalexo Posts: 159
    edited October 2012
    Lol, that is funny skrol. Nspindel if you just switch the driver with one that is working properly you will be able to determine if the problem is more than the driver, but I'll bet it's a bad unit. There shouldn't be any break in period.
  • nspindel
    edited October 2012
    No doubt about it. Monkey fell out of tree. Bad driver!
