mods on the 12c's, tweets?
soundfreak1
soundfreak1 Posts: 3,414
edited October 2012 in Vintage Speakers
Seems to be a ? As weather i can upgrade the rdo 194's in my rta 12c's to the 198's. Planning a full mod but can the tweets "BE" upgraded to the 198's. I understand it would need cap changes and maybe even risistor changes too but can it be done???
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • soundfreak1
    edited October 2012
    I sware i read a thread here somewhete on it being done but cant find it. So just asking if anyone jas done it?
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 50,753
    edited October 2012
    I yanked my sda cable on my 2A's one night and used 198's and had great fun. I don't recall the final TL as a spectacular pass or fail.
    What does yanking the SDA cable have to do with the tweeters or the TL mod? Answer, not an effing thing.
    Final TL? WTF are you talking about? Simply slapping a pair of RD0198-1 tweeters in your speakers is not a TL upgrade.
  • westmassguy
    westmassguy Posts: 6,850
    edited October 2012
    Smallies wrote: »
    Seen a lot of hair-trigger "NO!",s on these questions. I yanked my sda cable on my 2A's one night and used 198's and had great fun. I don't recall the final TL as a spectacular pass or fail. Def need to try those out again but will now be using 3000's cause the 198's found a home.
    There is no "TL" Mod for the 2As. The SL3000s you're using are not correct, nor would the SL2500 or the RDO-198. The only Tweeters that are compatable with the 2As crossovers are SL2000s and RDO-194s
    The T/S parameters for the two groups are very different.
    To the OP, I've seen RTA 12s with Peeless tweeters, SL1000s, and SL2000s. The Schematics available here, only show the later version with SL2000 (and probably SL1000 compatable). The Hi-Pass section is pretty elaborate on the RTAs. I'd stick with the RDO-194.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • soundfreak1
    edited October 2012
    Hey guys we are talking about RTA 12C'S here not SDA'S any info on the RDO198 upgrade on these speakers would be very helpfull. Thanks
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    F1nut Posts: 50,753
    edited October 2012
    There is no TL upgrade for your speakers.
  • soundfreak1
    edited October 2012
    Thanks F1.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
