FXi A4 Height, Placement and one stupid question
Noc1200GS
Noc1200GS Posts: 7
edited October 2012 in Speakers
I just picked up some FXi A4's to replace my "not so perfect for my setup" Monitor 40's. I have a small HT room with Monitor 70's front's and a CS2 center. The couch is up against the back wall so the large monitor 40's i had for the past 2 years were giving way less that optimal sound imaging. Since they were aiming at the TV and the speakers were almost in front of you, if you put your head back on the couch.
So I picked up some FXi A4's to fix the rear surround issue. But I have a few questions since I now have mounting options that I didn't have before. The room is 12.5' wide ( tv wall) X 11.5' deep and 8' high. The couch is 7' wide, leaving about 2.5' on each side of the couch.
I heard to put them at ear height, but then I hear to put them 2' above ear height? Also how far away from the couch should I put em? Maybe center them in that 2.5 foot area of wall between the couch and the other wall?
And now the dumb question. Intuition would tell me to have the woofer side of the FXi A4 aimed TOWARDS the listen/center, but if i read the speaker labels right, the woofer sides of the A4's aim AWAY from the listener/center. Is that right? Im assuming so, since they are labeled and all, but it seem counter intuitive to me. But that coming from a guy who just bought his first set of dipole/biopole surrounds. :cheesygrin:
Thanks in advance for any help/input. :cool:
Post edited by Noc1200GS on
  • ravaneli
    ravaneli Posts: 530
    edited October 2012
    I have fx500 and i thought the woofer faces the center. I have go recheck now after i read this :)
    Surrounds are mounted higher than ear level, mine are a full foot higher, but my side walls are also much further than yours
    They will be much better than the M40s for surrounds. Just put them on the wall on the same line as the couch and a little higher.
    May be experiment with a few locations before attach them permanently
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • tommyt21
    tommyt21 Posts: 685
    edited October 2012
    Noc1200GS wrote: »
    I'm slightly confused Surrounds in a 5.1 are not in the rear position. They should be to the side that may be part of your issue if I understand your setup correctly.
    Please take a look at the Dolby 5.1 diagram those M40's should have been mounted 90-110 degrees to the side of the listening position not to the rear on the back wall. Approx tweeter hieght 2 foot above the ear angled toward the listener. Run calibration for distance and channel level. My M40's work great as surrounds.
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • Devlon
    Devlon Posts: 355
    edited October 2012
    Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
    2 x Mirage OMD-5, 1 x Mirage OMD-C1, APC H15, Sony S790, Philips 52" LCD, Beogram 3000, FAT (Firestone Audio Tobby DAC), Harmony One
    Den: Sherwood R-972,as pre/pro, 2 x Velodyne SPL-1000R, 3 x Crown Drivecore XLS1500, 2 x Polk Audio Lsi9
    1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151
  • zane77
    zane77 Posts: 1,696
    edited October 2012
    The A4's are marked left and right for positiong but you can try them both ways. I would mount them on the side wall not the back wall.
    Two Channel
  • pdxfj
    pdxfj Posts: 376
    edited October 2012
    Umm.. you're in a tough situation. Anyway you can move the couch off the back wall a couple of feet?
    Ideally side surrounds should be placed 2-3 feet above your head. If you can move the couch a couple of feet forward so it's off the back wall, place the A4's at the height mentioned and slightly behind you. The side with the tweeter and woofer face the front of the room. Make sure the switch on the back is set at di-pole.
    If you are unable to move the couch off the back wall, then try placing them on the back wall at either end of the couch, about 2-3 feet up with the woofers facing each other and put the speakers in bi-pole mode.
    The A4's need breathing room when used as side surrounds. When in di-pole mode the rear facing tweeter fires out of phase with all the other speakers. This coupled with them placed slightly behind you creates the wider/open rear sound stage. If the rear facing tweeters are pushed into or are too close to a corner it will really mess with the sound quality.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited October 2012
    tommyt21 wrote: »
    "Surround" is the generic term for any speaker that is not in the front. Front speakers are usually referred to as either Front, or Main, L&R, and of course, there's the Center speaker. With 5 channel setups, some refer to the "other" two speakers as Surrounds. They may be either to the side, slightly behind, or behind the listening position, but not really directly behind. With 7 channel or greater, the terminology gets more confusing. Some refer to Side Surrounds and Back Surrounds, while others refer to the speakers on the sides as just plain Surrounds and those in the back as Backs. Really, the distinction is silly. A stereo pair of speakers is always in front of you - everything else surrounds you. Yes, generally, it's recommended that surrounds should be mounted above the listener's ear level. I prefer about 2 to 3 feet above, depending on the distance they are placed from the listener.
    Take a look at the articles in the Polk University - particularly these:
    http://www.polkaudio.com/polk-university/articles/home-audio-speaker-placement
    http://www.polkaudio.com/polk-university/faq/where-do-i-place-the-surround-speakers-in-my-room-for-the-best-performance
  • mdaudioguy
    edited October 2012
    Btw, the last link specifically mentions rear wall mounting, but as a less-than-ideal solution. Also, check this out:
    http://www.polkaudio.com/polk-university/faq/what-is-dipole-and-bipole-and-how-are-they-different
  • badchad
    badchad Posts: 348
    edited October 2012
    Would you guys recommend the use of something like an omnimount bracket, just to get the speaker off of the wall a few inches and offer a bit of flexibility in direction/movement.
    Polk Fronts: RTi A7's
    Polk Center: CSi A6
    Polk Surrounds: FXi A6's
    Polk Rear Surround: RTi4
    Sub: HSU VTF-3 (MK1)
    AVR: Yamaha RX-A2010
    B&K Reference 200.7
    TV: Sharp LC-70LE847U
    Oppo BDP-103
  • tommyt21
    tommyt21 Posts: 685
    edited October 2012
    mdaudioguy wrote: »
    I understand all of that, I was just pointing out if I understood his layout correctly rear mounting for a monopole speaker was probably less than ideal in his situation. Thanks for the links though thats great info!
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • cowtrimmer
    cowtrimmer Posts: 201
    edited October 2012
    I use 40's for surrounds that are facing each other 23' apart and they sound pretty good. I used to have them pointed at the listening position and wasn't happy.
