I wonder what Matthew Polk runs for speakers
polkrt3000p
polkrt3000p Posts: 126
edited October 2012 in The Clubhouse
I was wondering what he using in his home, does he use the SRT, SDA SRS or something else. What he likes for Amps and Preamps to drive them.
Post edited by polkrt3000p on
    pitdogg2 Posts: 25,671
    edited October 2012
    at one time there was a picture of Lsi7 or 9's he was using and had a SDA like set up with active crossovers
  • newrival
    newrival Posts: 2,017
    edited October 2012
    Interesting question.
  • gce
    gce Posts: 2,158
    edited October 2012
    I think he has a full on Bose system! :razz::lol:
    Anaheim Hills CA,
  • nspindel
    nspindel Posts: 5,343
    edited October 2012
    Klipsch, for sure.
    edited October 2012
    There's a thread on that here. Or you can look through the old Polkfests, probably 4 years ago when a number of the old timers visited with Mr. Polk. He had 4 LSi-9s wired and crossovered SDA style and some large Threshold Stasis power amps, if I recall that post correctly. If not, someone will jump in?
    OK, I see that is NO longer in the system showcase.
    So WHERE did the pics of the previous Polkfests that were in this area GO?
    cnh
    edited October 2012
    cnh wrote: »
    There's a thread on that here. Or you can look through the old Polkfests, probably 4 years ago when a number of the old timers visited with Mr. Polk. He had 4 LSi-9s wired and crossovered SDA style and some large Threshold Stasis power amps, if I recall that post correctly. If not, someone will jump in? cnh
    must of been where i seen them also
  • sda2mike
    sda2mike Posts: 3,131
    edited October 2012
    i'm sure he has our sickness, upgraditis..only in a very advanced stage! imagine the access to cool gear this guy has! i'm sure matt polk's opinion means alot to companies in this industry
  • madmax
    madmax Posts: 12,434
    edited October 2012
    Last I heard, years ago, he was setting up some massive sub system, not sure about the mains.
    Vinyl, the final frontier...
  • ESavinon
    ESavinon Posts: 3,066
    edited October 2012
    Isonic Radio.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • codyc1ark
    codyc1ark Posts: 2,532
    edited October 2012
    ESavinon wrote: »
    Waveradio.
    Fixed. :smile:
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited October 2012
    This is what he had at the time of the the 2008 Polkfest:
    Home Theater: Two sets of LSi9's configured in an SDA arrangement with an external DSP crossover and a huge subwoofer system built into the floor.
    Two Channel: LSi9's driven by a pair of Threshold SA-1 monoblocks (160 wpc (8 ohms), 300 wpc (4 ohms)). I don't recall which preamp and CD player he used.
    Matt Polk discusses his home theater system.
    Custom in-floor subwoofer system.
    LSi9's in home theater.
    Two channel system amps: Threshold SA-1 monoblocks (160 wpc (8 ohms), 300
    wpc (4 ohms)), MSRP $6,000 per pair in 1986.
  • newrival
    edited October 2012
    That appears to be an infinite baffle setup for the subwoofers. although perhaps it isn't as there are what appear to be ports sticking up. Perhaps he didn't have the volume below to go IB and built an enclosure with ports for better increased sensitivity.
