My computer took a massive dump
nooshinjohn
nooshinjohn Posts: 25,396
edited October 2012 in The Clubhouse
It.does not boot up at all, even in safe mode. All was working well until it did the usual restart after getting weekly updates from Microsoft. It is not even sending a video signal out, so literally there.is nothing I can. See to even begin to troubleshoot with.
The computer is a 5 year old Gateway FX7026 with 64 bit windows vista, intel quad q9300 and nvidia 8800 over locked graphics card. My first impulse is that the card is dead, but the computer fans run full speed and do not slow down as they usually did. Any advice on getting it fixed or recovering the data from it and transferring it to a better machine?
Post edited by nooshinjohn on
  • KiTsuNe
    KiTsuNe Posts: 74
    edited October 2012
    Recovering data is easy, if you're going to get a new computer you can pull the hdd out of that system and get a usb adapter/enclosure and still access your data with a few setting changes on your new machine.
    If you're looking to try to save this machine there's a few things to look at.
    Does it power up? You say your fans turn on so I do not think your PSU is the issue.
    Do you have an onboard video port? If so try pulling the video card and seeing if you can get a signal from that.
    If you do not you can try buying a cheap 20 dollar PCI-E card to see if your old card is the culprit.
    If you still can not get a video signal even with a new card (not even post) I think it might be the motherboard.
    With that being a possible issue I'd just scrap it for new tech. Parts are very cheap now if you go mid grade or last gen tech.
    To transfer/recover data just get an exclosure and stuff your old hdd in it. Hook it up to your new computer and give yourself administrative rights over that drive. Once so you should be able to access it like a normal hdd and pull your data out.
    HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
    Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
    2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
    Desk: QSC RMX850/Behringer B2030P
  • 11tsteve
    11tsteve Posts: 1,166
    edited October 2012
    or the old HDD can just be hooked up internally to a second computer's SATA port on the mobo. as long as there is a primary boot drive/windows install, the old install of Vista will just show up as a data drive and you would have full access to all of the files. no need for an enclosure.
    does the stand-by light on the monitor stay in the stand-by color? have you completely powered down and then tried rebooting?
    i assume you have opened the case and reseated the GFX card, RAM sticks and such?.... seems an odd coincidence it happened right after updates. i was wondering if there might have been MS graphics drivers in the updates you installed (they are usually crap) but you should at least at a BIOS/splash screen.
    any USB devices plugged in?
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • Syndil
    Syndil Posts: 1,582
    edited October 2012
    First thing to ask is, does it beep? If it beeps but no video, most likely the vid card. If it does not beep, something else may be wrong. Pull the card, see if it beeps. If that doesn't work, pull the memory, then any other cards until you get it to beep. If it never beeps, either a bad PSU or bad mobo.
    If it beeps more than once, need to know the beep pattern to diagnose the error.
    edited October 2012
    no beeps,clicking, hard-drive spool-up... nothing but the fans and a flashing internal green on a board inside and the orange powerup light that shines through the power switch. I am leaning towards CPU failure as of this moment...
  • Syndil
    Syndil Posts: 1,582
    edited October 2012
    Theoretically, if the CPU is bad, the mobo will have a beep code for it. But sometimes if a component goes bad it will prevent the mobo from beeping at all. At this point it's going to have to be a process of elimination.
  • dorokusai
    dorokusai Posts: 25,577
    edited October 2012
    HDD fail all the time, MOBO's less than but PSU's can also drop like a rock. You're in for some reality based troubleshooting. Start with the PSU, get the adapter and see if your HDD works on another computer. You need to know those two things now.
    edited October 2012
    My hard-drives are configured in RAID, so I don't know how I could test them, as it is my understanding that they need to work together. Is it possible that the power supply is just not able to provide enough juice to turn everything on, but still work enough to give me a good power light?
    I am such a newb when it comes to this crap?
    EndersShadow Posts: 17,590
    edited October 2012
    Syndil wrote: »
    Agreed, and its a PAIN to play what I call "Component Roulette"
    dorokusai wrote: »
    Well according to him (just talked to him on the phone) the computer power light comes on and the fans all spin up to 100% rpm and then never slow down. Given that I would assume the PSU is good but that the computer simply will not POST (he used to get beep codes but no longer does)
    John, normally if the PSU has worked for a long time and you still get power and fans turning on, your PSU is good, its something else. That said computers are quite complicated so its possible, but to me unlikely.
    Also in discussing things with him the entire interior was entirely covered in dust and I assume cat hair from their cat. Dust/hair + computers = trouble.
    He also mentioned that in the past few days he was getting errors while watching video's/using the display that were of video card failure upon which the computer would then restart to the splash screen.
  • dorokusai
    edited October 2012
    ****, the answer is always ****.
    edited October 2012
    dorokusai wrote: »
    Nah, he was watching Glenn Beck TV. His computer just COULDNT HANDLE THE TRUTH!!!!! :biggrin:
  • sucks2beme
    sucks2beme Posts: 5,601
    edited October 2012
    My audio server just started acting up. power supply? No, becasuse I have a spare and that
    would be too easy. I was thinking about an upgrade anyway. About $80 for better mb/cpu at Fry's, plus
    about $26 for 8 g of ram.
  • Willow
    Willow Posts: 11,008
    edited October 2012
    odd, my desktop crapped out the other day. Immenent HD failure. Now I'm trying to load windows in a HD I had used for backups but no luck what so ever.
  • cowtrimmer
    cowtrimmer Posts: 201
    edited October 2012
    I would just take the hard drive out and not stick anything into a 5 year old machine. Get an enclosure as stated above and use it for a back-up after you get your files off from it. http://www.newegg.com/External-Enclosures/SubCategory/ID-92?Tpk=hard%20drive%20enclosure|drive%20enclosure
  • vc69
    vc69 Posts: 2,500
    edited October 2012
    dorokusai wrote: »
    Unequivocally so. Except this is John, so...
    most likely
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Drenis
    Drenis Posts: 2,871
    edited October 2012
    Sounds like it got too hot and or fried something due to the dirty mess.
    You could take it down to bare bones, clean it good, remove/reinstall CPU, re-seat the heatsink and reinstall 1 stick of memory and a random HDD other then your array. See if it posts.
  • Face
    Face Posts: 14,340
    edited October 2012
    Sounds like it's time for an upgrade anyway.
    edited October 2012
    posting from best buy on my new Apple iMac...
    Seriously though, I am getting a new dell XPS with 32G ram and 2TB hard drive space... should be good enough for running the new house.
  • Face
    Face Posts: 14,340
    edited October 2012
    16 gigs of ram still has plenty of headroom with Adobe PS, Firefox, and Battlefield 3 running at once, why would you need 32 gigs?
  • jjwm27
    jjwm27 Posts: 123
    edited October 2012
    my comp did the same thing, try clearing the cmos and see if you can get a video signal, unplug the computer and remove the battery, wait for a minute and install the battery and plug it in and see if it will work. fixed mine right up. it will reset your bios settings. good luck.
    edited October 2012
    Drenis wrote: »
    The 2nd 3rd and 4th RAM slots are bad and the 1st is iffy. We got it to post with 1 stick of RAM (then tried 2 and no POST) and he is having the data dumped off it now onto a new computer as we speak (It was still having issues with just 1 stick which realistically Vista doesnt run well on 1-2 gig of RAM anyway. Then he's going to backup all that data to an external HDD for safekeeping.
    Face wrote: »
    Agreed.
  • Drenis
    Drenis Posts: 2,871
    edited October 2012
    I knew something got hot; RAM.
    Yes... I know all to well of Vista's issues with the low memory.
    edited October 2012
    sucks2beme wrote: »
    I went through all available solutions, and it was just cheaper to upgrade. The MB and CPU would have been 325.00 by itself...
    The reason I am so very reluctant to put media on a computer is for this very reason. I will never loose my data that is stored on vinyl.:cheesygrin:
    edited October 2012
    Face wrote: »
    I do plan on using this computer as a central component and an extension of my Pioneer SC-37. I want the speed and the 2TB of hard drive to give me the memory space to be able to store a few things and not be concerned about running out of room. I am also going to forego DTV or cable for a bit and see if Netflix/Hulu can work for us instead. This computer should have the power and the speed needed to deliver. I am going to upgrade the audio card however...
  • dorokusai
    edited October 2012
    The suggestions so far are not able to be argued...solid. I'm am audio guy not a computer guy and some might argue the other.
    I JUST rebuilt my own so I cannot offer much more than YES, its time for change and YES go SSD. You should always backup your crap but I've had so many standard HDD fail me over the years that I wanted something different. I backup, no big tragedy but it freeaking sucks, period.
    I'm also not in love with this INTEL Board since I've been an ASUS dovotee for more than a decade. That being said....WTF can I say? Everything works, I'm happy. My speeds are high, my temps are almost non-exisistent and its quiet. I'm the lamest game player so I'm tickeld but when it comes down to brass tacks....I'm heavy and ready.
    My only regret is not sticking with ASUS but since I'm running dual ASUS monitors....I'm sure they're ok.
    For those not used to or think dual monitors is weird....once you go there, you'll never go back. It's really helpful for multi-tasking and not just being nerdy. You can do a lot more business with two and not lose focus....hard to explain.
  • Face
    Face Posts: 14,340
    edited October 2012
    It's still overkill, but it's your money. If you want speed, go with Mark's suggestion of a SSD for the OS, browser, etc..
  • obieone
    obieone Posts: 5,077
    edited October 2012
    2 monitors= carpal tunnel AND tennis elbow. No thanks:cry:
  • dorokusai
    edited October 2012
    obieone wrote: »
    I don't know about you but my arm movement in hardcore mouse mode is tame at best. You might need professional help if Carpal Tunnel is a factor, LOL. Now your eyeballs? Well, that's a different issue since I've started having seizures but I think they're neat.
  • greg2350
    greg2350 Posts: 544
    edited October 2012
    I wouldnt jump on SSD yet problems installing OS on SSD drives. Drives degrade over time. Lots of reviews of SSD drives failing.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,726
    edited October 2012
    greg2350 wrote: »
    This is 2012, not 2008.
    You have to do your research obviously, but SSD is a mature technology and is plenty safe to use in a PC
  • AsSiMiLaTeD
    edited October 2012
    I disagree.
    I have lots of stuff on vinyl and on CD and if our place burns to the ground or gets robbed I'm screwed, I can't 'copy' stuff that I have on vinyl.
    For all the media I have stored digitally, I have a redundant backup system:
    - I'm all Apple at this point, and I'm using Time Machine so if my computer fails I can just restore my backup to a new machine. I'm sure there's a version of this that works just as well on Windows, so there's no reason not to backup.
    - I also have all my media on an external drive, and that's the primary drive I use for playback in iTunes and streaming to boxes around the house.
    - I have a second external drive that I back up to weekly or so, and I bring that drive into the office and keep it here. So if our place burns to the ground I'm covered. Technically I have two of these that I rotate, so one is always at the office.
    - For my media (so no personal information) I also use an online storage solution. It's cheap and works well, so if my office and house BOTH burn to the ground I'm covered.
    That may sound like overkill, but it's really very simple and inexpensive.
