Polk Audio PSW125 b lowing fuses
jogalind
jogalind Posts: 1
edited October 2012 in Troubleshooting
My Sub was working fine last week and now is blowing Fuses. Has anyone had this problem and found a fix for it?
Thanks!
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited October 2012
    Hello jog,
    Thanks for posting on Polk's forum. Blowing the AC fuse on a bass amplifier usually means a problem with the amplifier or the woofer that's connected to it. It would be best to contact Polk's CS department at 1-800-377-7655 or via email at polkcs@polkaudio.com. They'll help you troubleshoot the problem and get it solved.
    Regards, Ken
