3x RTiA7?
BiduleX
BiduleX Posts: 4
edited November 2012 in Speakers
In my home theater I have an acoustic screen. So I'm going to put Left, Center, Right behind it. Instead of using two RTiA7 and one CSiA6... Can I use three RTiA7?
:question:
Post edited by BiduleX on
  • pdxfj
    pdxfj Posts: 376
    edited October 2012
    Using three of the same speakers behind an AT screen is by far the best way to go. If I had a few more feet of depth to my HT, I would have gone the same route as you.
    Hope you've got a powerful AVR or an external amp. Three A7's are going to eat up some power.
  • tommyt21
    tommyt21 Posts: 685
    edited October 2012
    I believe that is the preferable method for a close to accurate front soundstage. I am sure some of the more experinced members will chime in soon.
    I say get Dolby Pro Logic IIx and run wides...thats 5 A7's in the front muwahahahaha! lol
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
  • ravaneli
    ravaneli Posts: 530
    edited October 2012
    with any other speaker i'd say go for it. But with the A7s vs A6.. no way. The A6 will kill the A7 as center. Two large mid drivers and simple construction.. If Anything I would go 3 x A6 for the front!
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • mystik610
    mystik610 Posts: 699
    edited October 2012
    You're not thinking of turning the RTiA7 on its side are you?
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • tommyt21
    tommyt21 Posts: 685
    edited October 2012
    ravaneli wrote: »
    You may want to read up on Horizontal vs Vertical dispersion with MTM driver arrangements. It explains why a vertical driver arrangement (A7) is better than a horizontal (A6). One of the main reason center channels are horizontal is because of home user placement. Also the A7 puts the tweeter height all the same level near the sitting ear hieght in most cases.
    PS: I know that the A7 isn't exactly a MTM array but i believe the concept is simlar.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • BiduleX
    BiduleX Posts: 4
    edited October 2012
    mystik610 wrote: »
    No! :eek:
  • mystik610
    edited October 2012
    BiduleX wrote: »
    No! :eek:
    Hah just checking. People have tried!
    My System Showcase!
    Media Room
    Living-room
    Headphones
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2012
    I'd take the csi a6 over the a7.
  • jaf09
    jaf09 Posts: 48
    edited October 2012
    i got the a9s and think they sound better then my rti a6, but also put out a lot more bass i think it may be overkill on the bass side
  • BiduleX
    BiduleX Posts: 4
    edited October 2012
    I'm new here... Is there any Polk Audio employees reading these posts? They might have already done the test?!
  • CRESCENDOPOWER
    CRESCENDOPOWER Posts: 153
    edited October 2012
    If the middle of your ears are 39 inches in height when seated then yes the RTia7 is the answer. Otherwise, the CSiA6 is the ticket.
    tonyb Posts: 33,066
    edited October 2012
    BiduleX wrote: »
    It's not necessarily a test per say but a matter of preference. Idealy, 5 channels of full range speakers would be the ticket, especialy for multi-channel music playback, but how many have room for 5 full range speakers ? If your one of the lucky ones, then yes go with all full range speakers, even if it's only the front 3 speaks.
  • gp4jesus
    gp4jesus Posts: 2,016
    tommyt21 wrote: »
    You may want to read up on Horizontal Vertical dispersion with MTM driver arrangements...
    +1!
    tommyt21 wrote: »
    ...I know that the A7 isn't exactly a MTM array but I believe the concept is simlar.
    +1 and the TM array has imaging advantages over MTM* and let's not talk about its* comb filter issues.
    Merry Christmas, Tony
    *all connected w/Premiere ICs
  • gp4jesus
    BiduleX:
    pdxfj wrote: »
    what do you have to drive your LCR ?(3 RTi A7s!) Should be 4 ohm stable if you're gonna crank it!
    BTW: How big is your room?
    Tony
