No sound from tweeter please help.
KiTsuNe
KiTsuNe Posts: 74
edited November 2012 in Troubleshooting
I turned on my equipment today and realized that the tweeter in one of my RTi A7's isnt working. What should i do to test what is wrong? I tried hooking it up to 4 different amps and still no go. Everything else seems to work just fine though.
HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
Desk: QSC RMX850/Behringer B2030P
Post edited by KiTsuNe on
  • gce
    gce Posts: 2,158
    edited October 2012
    Are you bi-wired or bi-amped?
    Anaheim Hills CA,
  • hewlew1
    hewlew1 Posts: 154
    edited October 2012
    Do you own A multimeter? If you do remove the tweeter and check to see if the voice coil is open.
  • KiTsuNe
    KiTsuNe Posts: 74
    edited October 2012
    i have a multimeter, theres no resistance when i touch the two leads after i disconnect the tweeter. I also swapped it into my other A7 and no sound from the tweeter.
  • hewlew1
    hewlew1 Posts: 154
    edited October 2012
    It sounds like its time to buy a replacement tweeter. You can contact polk to find out how much they cost and tell them you are a member here on this forum I believe it gets you some degree of discount when ordering replacement parts. Or you can try that auction site and see if any used ones are available.
  • KiTsuNe
    KiTsuNe Posts: 74
    edited October 2012
    X.x called earlier, hopefully the other one doesn't go either.
    F1nut Posts: 51,818
    edited October 2012
    You more than likely sent a clipped signal from the amp that drives your fronts. Clipping will occur when the volume level spikes or is flat out too high and the amp doesn't have the power reserve to handle it. Looking at the specs for your amp I see it weighs 18 lbs., which means it doesn't have much of a power supply. Hell, I've got CD players that weigh more than that. The solution is to either keep the volume level lower or buy a beefer amp(s).
  • KiTsuNe
    KiTsuNe Posts: 74
    edited October 2012
    Yeah, i know my amps arent great in the HT, I do want to upgrade to better amps soon.
  • SugarmillMan
    SugarmillMan Posts: 175
    I think your tweeter is DOA. :(
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
