Stick With Mylar?
deronb1
deronb1 Posts: 5,021
edited October 2012 in Vintage Speakers
I am shopping caps to replace the old caps in a pair of SDA 2Bs I just got. My SS 2ch stuff definitely leans towards the bright side, (see sig) eventhough the tube buffer has softened up things a bit.
Was wondering if maybe new mylars might be a consideration to keep that smooth controlled sound?
Post edited by deronb1 on
  • drumminman
    drumminman Posts: 3,396
    edited October 2012
    My only experience is with polypropylene (sonicap Gen 1), and I would not characterize them as bright.
    They're one of the more popular brands for rebuilding Xovers, Clarity Cap being another. Of course caps are available at all price levels, but as with most things you get what you pay for.
    What's your budget?
  • deronb1
    edited October 2012
    I dunno. Probably a hundred bucks or so for the upgrade. Also want to get RDO 194s, so there is another hundred bucks.
  • nhhiep
    nhhiep Posts: 877
    edited October 2012
    if you want to remove that bright sound, your first fix is replacing the stock tweeters. I did that on my 1Cs
  • deronb1
    edited October 2012
    Probably a good idea. Will let the caps be for awhile. Opened it up and nothing is leaking
    F1nut Posts: 50,753
    edited October 2012
    Do the TL upgrade using film/foil caps, Mills and the RD0198-1's........worth every penny.
  • Phasewolf
    Phasewolf Posts: 514
    edited October 2012
    Yes F1 is right if you are redoing it go for the TL mod it will sound that much better and RDO-198 tweeters are the same price as the 194's
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
    pitdogg2 Posts: 25,689
    edited October 2012
    plus 1 Mylar would be a waste of money. you should have some Mylar in there now I believe along with the electrolytic
  • westmassguy
    westmassguy Posts: 6,850
    edited October 2012
    There's a reason the Mylars were all bypassed with small, Silver Mica caps, they're not that good. As others have said, the RDOs are vastly superior to what you have now. If price is factor, Clarity PX or Dayton 1% metalized polypropylenes will do the job nicely, and not break your wallet. You can also get rid of the Silver Mica caps, polypropylenes don't need them.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • PolkieMan
    PolkieMan Posts: 2,446
    edited October 2012
    Why is the 198's better?
    Phasewolf wrote: »
    F1nut Posts: 50,753
    edited October 2012
    I can't give you the reason why, they just sound better to my ears.
    I replaced the SL2000's in a pair of CRS+'s with the RD0194-1's. It didn't sound right, kind of muted/hollow. I then did the TL mod with the RD0198-1's and that did the trick.
  • PolkieMan
    edited October 2012
    I wonder if the results would vary from speaker model to model example the CRS+ benefit more than say the 1C?
    F1nut Posts: 50,753
    edited October 2012
    The SDA 1C can't use the RD0198-1, but that's not my point. Polk designed the SL3000 as an improvement over the SL2000, so whatever characteristics it had were applied to the RD0198-1 and improved upon again because the RD0198-1 is definitely better than the SL3000. That's not to say the RD0194-1 is a bad tweeter, it's a definite improvement over the SL2000 and I would strongly suggest replacing it with the RD0194-1.
    One would have to hear the RD0194-1 and the RD0198-1 in the same speaker to appreciate the differences. To my knowledge, no one that has performed the TL upgrade to a model that supports that change has ever gone back to the RD0194-1.
  • PolkieMan
    edited October 2012
    I replaced the tweets in my 2.3tls with 198 and 1c with 194 and I was thinking of doing 198 in my 1c after you saying they were better but I see that cannot be done.
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2012
    I can't be done because electrically they are not compatible. You would have to revamp the crossover totally to get them to work and even then I would think there could be issues sonically.
    Since you have 2B's you are a solid candidate for the TL mod. Run don't walk and do the TL mod. Your ears will thank you for it.
