DSW MicroPro1000 Not Working
polkpolkpolk
Hi,
I'm having trouble with my MicroPro 1000 subwoofer. I had it plugged in to a power bar which I had to shut off and unplug. Once I plugged everything back in and started it up, I noticed the subwoofer was unresponsive. (ie. no noise, no blue light, etc.) I unplugged it for a few minutes (~5) and when I turned it back on the Polk logo on the front blinked five times. There are no lights lit up on the back panel (usually there is an orange/green light when the sub is in standby/on). I unplugged it and tried again. I'm not even getting a consistent amount of blinks when I plug things back in and try again.
I assume if it's the fuse the front light would not blink at all, but that is just an assumption on my part. I'm not sure how to get the fuse out anyway.
I will leave it unplugged for the next day and try again.
In the meantime, does any one have any other suggestions for what I might try?
I absolutely love this sub, but unfortunately it is out of warranty, so I'm hoping the fix is not too expensive.
Post edited by polkpolkpolk on
Hello polkx3,
Sorry there's a problem. One thing to try is to unplug the AC power cord, switch the function selector to "off" then reconnect the power cord. Set the selector to "on" and see what happens. If still no operation call Polk's CS number of 1-800-377-7655 or send them an email to polkcs@polkaudio.com
Regards, Ken -
Thank you Kenneth. I will send them an email.
