RCA Interconnects
rromeo923
rromeo923 Posts: 1,513
edited October 2012 in 2 Channel Audio
Ok I really have yet to hear any difference in cables. Still I am interested in getting a pair or two of inexpensive but better than the ones that came w/my vcr cables.
I actually was using some really old super cheap ones that may have come w/my vcr in between my preamp and amp.So I changed them to some old Monster cables I had sitting around. Well it turned out that one of the Monster cables was bad and I could definitely hear a difference between the good one and the bad one, my one speaker was definitely louder.
So I decided maybe I should buy a set or two of decent cables. I want to be under $100.
Any suggestions?
Any ones that can be purchased w/ 30 day guarantee?
I already have Monoprice cables. They sound the same as all the other ones I have ever had. Anyway suggest away.
I would have no problem w/used cables too if anyone has some they want to sell on the cheap.
I got static in my head
Post edited by rromeo923 on
  • brgman
    brgman Posts: 2,859
    edited September 2012
    Talk to pepster.He can fix you up.
    I’M OFFENDED!!!!
  • dracoskeeper
    dracoskeeper Posts: 142
    What lengths do you need?
  • rromeo923
    1 meter
  • rromeo923
    Brgman thanks.
    I will hit him up.
  • chumlie
    chumlie Posts: 8,658
    brgman wrote: »
    +1 on the pepster. Just keep him away from the 40 Creek.
    EndersShadow Posts: 17,722
    Signal Cable is also a good RCA interconnect to start with. Frank gives Club Polk members a discount.
    Analog 2 are what I would get.
  • Face
    Face Posts: 14,340
    What's your setup?
    Will you be listening in 2 channel? If so, I'd go with Ender's recommendation of SignalCable Analog 2, but with Bullet RCA's?
    F1nut Posts: 51,997
    I suggest you sign up for the MIT Cable Demo/Review.
  • Upstatemax
    Upstatemax Posts: 2,798
    Another big fan of the Signal Analog 2. I have the bullet plugs also,but they do get pricey if you're looking to stay to on a budget.
  • wkjeffers
    wkjeffers Posts: 139
    DH Audio makes good affordable cables
  • wkjeffers
    I also suggest looking on Agon or AA and finding some used Kimber Heros, they can be found for $100 to $125 for a meter pair if you are patient. They are very good cables
  • classic carl
    classic carl Posts: 662
    Avanti Audio also make very good cables. Mike makes RCA, XLR, and also speaker cables. I believe he offers a 30% discount if you are a memeber of Audio Karma. He is a member there also. A one meter pair starts at $50. No affiliation.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • zingo
    zingo Posts: 11,258
    Another bump for DH Labs; their budget cables are great.
  • Blownrx7
    Blownrx7 Posts: 137
    zingo wrote: »
    Another vote for DH Labs. Based on all the chatter, you can't go wrong with Signal Cable either. OR DIY it with some DH Labs or Mogami cable.
    Flame suit on:rolleyes:
    The issue with whether cables make a difference has a lot to do with the quality of the system you are dealing wth. If you have a lo-fi or even mid-fi system, the incremental improvement a good set of cables may make will be washed out by the capability of the system. Think mp3 and Ipod. If you are using a low bit rate source, it stilll is going to sound like crap whether you are using the cheap throwaways or the $1000 cable. It's all about distortion and noise.
    That being said, I've always felt that the quality of the connection can have a more significant impact whether it is on a $5 or $5,000 cable. The solder joint (amazing what passes for workmanship on even some of the expensive cables) and the connector are critical to good sound.
    Spend the money on a good quality connector, get some reasonably priced cable and enjoy the 95% (99.44%:smile:) benefit.
  • sucks2beme
    sucks2beme Posts: 5,691
    No flame suit needed. We understand that many try cables early on and can't hear a difference.
    When you move up, little stuff starts to matter more and more.
  • zingo
    zingo Posts: 11,258
    For DIY, Luminous Audio silver locking RCAs are my favorite and reasonably priced for a premium RCA.
  • trans am
    trans am Posts: 91
    zingo wrote: »
    I was in the same boat as you. I was going signal cable all the way then at the last minute I borrowed my friends anti cables to test on my rig. All I can say is holy crap! I even had my buddy blindfold me and we tested. the 1st 2 times he had my old cables in and then as soon as he plugged in the anti cables i could feel the difference. the sound just became consolidated. its as if the speakers were integrated to my amp. I would consider them if you havent bought your signal cables yet. I am new to this and never thought my cables would make a difference but i take it all back. try it and if you dont hear a difference you can send them back for a refund no questions asked. I spent more money on cable than my amp costs. if I were to make an analogy it was like going from a 10k raptor hard drive to 4 crucial m4 ssd's in raid0 on a lsi 9260-4i raid card. if you dont know what i mean then you should probably be spending your money on some ssd's instead of cables.
    Adcom GFP-750
    Adcom GFA-555II
    Monitor Audio silver RX2
    NAD T585 SACD
    Technics sl-1200mk2 / ortofon m2 blue (signal cable/ Eichmann mod / Sumiko HS-12 Headshell
    Jolida JD9 II / Mulllard Tubes
    SignalCable Ultra speaker cables
    SignalCable Analog 2 IC's
    "ROMANCE WITHOUT FINANCE IS A DAMN NUANCE CAN YOU DIG I???"
    Clipdat Posts: 13,100
    trans am wrote: »
    LOL, great analogy! That's some pretty high praise for anti-cables!!
  • dorokusai
    dorokusai Posts: 25,576
    Great job TransAm although I don't think I've heard a worse cable then Anti-Cables. Absolutely awful in my rigs but hey, you just never know when your gonna find success :biggrin:
    Mark
  • trans am
    trans am Posts: 91
    really? :( what is so bad about them? my heart sank.
    Adcom GFP-750
    Adcom GFA-555II
    NAD T585 SACD
  • dorokusai
    I just think they sound awful let alone are unwieldy to unwrap and manage properly. If you like them, awesome.
    It doesn't matter what I think but my bet is that you won't keep them long-term, you'll easily find something better and wonder why you even bothered. Just a thought.
    Mark
  • trans am
    trans am Posts: 91
    mark the reason I ask is I was going to get signal cables and then chickened out after reading some good things about anti cables.
    listen man, I have some radio shack cable so anything is better. I was drawn to pauls anti cables be cause he is from woodbury MN and I grew up in that town and they were less than the signals and he offered the eichman bullet plugs also. I am not in the market to buy 2nd sets of cables. I want it done the 1st time. considering my adcom pre and power amp cost less than the cables. has anyone tried both the signals and the anti cables? how can they sound aweful when I have radio shack cables, lsi7 and adcom pre and power amp? I am in NYC and so is the signal cable guy. If he would be willing to do a shootout between his cables and anti cables on my rig. this would be great. I will pay the deposit. both offer a return policy. we can even go to matrix audio and do the test there. Steve would love to do something like this.
    btw this was the anti cable break down
    - a 6 foot stereo set of Anti-Cable speaker wires with spades = $60
    - a 1/2m pair of Anti-IC with Eichmann plugs = $150
    - a 2m pair of Anti-IC with Eichmann plugs = $200
    - US Priority shipping = $8
    TOTAL = $418
    how much would the signal cable equvalent be with the eichmann bullet plugs on the ics?
    I wasnt aware polk members got discounts on signals. what are the savings?
    Adcom GFP-750
    Adcom GFA-555II
    NAD T585 SACD
    F1nut Posts: 51,997
    Then you want MIT Shotgun cables.
  • trans am
    trans am Posts: 91
    So is MIT Shotgun the standard? look at my rig first. I am obviously on a budget. What would MIT shotguns cost? where can I get them cheap?
    Adcom GFP-750
    Adcom GFA-555II
    NAD T585 SACD
  • trans am
    trans am Posts: 91
    I cant afford them. My rig is not even worthy of cables that cost that much. I chose the anti cables or signal cables for their price/performance.
    I just want to try both and see what sounds the best. I am trying to get some new life out of my rig. I came have lsi7 in 2 channel and was reading about bookshelf speakers in the $1k-$1500 range. I bought some Monitor audio RX2 cheap and want to compare to the lsi7 and keep the best of the 2.
    I bought the cables so I dont have a bottle neck when comparing the speakers. I copied paul from anti cables so he can see this thread and maybe get some polite feedback.
    Adcom GFP-750
    Adcom GFA-555II
    NAD T585 SACD
  • headrott
    headrott Posts: 5,496
    I think Jesse suggested Shotgun's (even S3's used) because when you move up in gear, you will be set for cables for a long while. You said "I want it done the 1st time" and that's why Jesse suggested MIT Shotgun's.
  • trans am
    trans am Posts: 91
    so if that is the case. I need to buy one set of cables at a time. what is the priority? what connection will yield the most noticeable improvement?
    the ic from the pre to the amP
    the speaker cable from the amp to speakers?
    the ic from the cd or turntable to the preamp?
    Adcom GFP-750
    Adcom GFA-555II
    NAD T585 SACD
  • headrott
    Many people say they get the most improvement with speaker cables. I started with IC's first however because I got a good deal on them. Two sets: one between my DAC and pre-amp, and one between my preamp and amp. I noticed a definate improvement with the Shotgun S3's in these two positions. I noticed a further improvement when I added Shtotgun S3 speaker cables last.
    Many people report an additive effect with adding MIT Shotgun cables. That is: the more you add, the more improvement you will gain, and I agree with this. Many people say to start with speaker cables, so I would start there. But, if you find a good deal on some interconnects, don't pass them up. As I said, I started with interconnects (although mine were balanced).
    Although, if doing IC's first; many people report the biggest improvement with the IC between the source to the pre-amp. Followed by the Pre-amp to the amp. Of course, this can depend on what source, pre-amp and amp you are using. But in general, the IC's between the source and pre-amp would yield the greatest improvement, followed by the pre-amp to the amp second.
  • trans am
    trans am Posts: 91
    thanks for explaining. I want to buy a new preamp. i was looking at the GFP-750 to replace my 500ii. the 750 has no phono stage. what do you recommend for phono?
    Adcom GFP-750
    Adcom GFA-555II
    NAD T585 SACD
  • trans am
    trans am Posts: 91
    360? View
    Other Products
    PreviousNext
    The larger RX2 is designed as an audiophile compact 2-way speaker, having the efficiency and bandwidth of a much larger speaker, while being easier to position around the home. It offers extended high frequencies to resolve hidden detail, coupled with immense dynamic headroom and bass depth, so that all the delicacy and drama of your favourite music and film sound is revealed.
    New C-CAM? tweeter design with damped rear chamber, providing improved clarity and wider operating range for HD audio formats
    New 8? bass driver with C-CAM? cone profile incorporating RST? technology for better damping and improved mid-range clarity.
    New cast polymer bass chassis design for better rigidity and lower reflection properties
    HiVe?II port technology for better transient response and tighter bass.
    Single bolt through driver system, for increased overall bracing and rigidity.
    Rigid 19mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
    Invisible magnetic grille fixing provides clean visual styling when used with the grille off.
    Selected premium quality wood veneers or high gloss piano finishes.
    Item Value
    System Format: 2 Way
    Frequency Response: 40Hz - 35kHz
    Sensitivity (1W@1M): 90dB
    Nominal Impedance: 6 Ohms
    Maximum SPL (dBA): 113.8
    Power Handling (RMS): 100W
    Recommended Amplifier Requirements (RMS): 25-100W
    Bass Alignment: Bass reflex - rear ported.
    HiVe?II port System
    Tweeter Crossover Frequency: 2.0kHz
    Drive Unit Complement: 1 x 8" RST? Bass/Mid driver. 1 x 1" (25mm) C-CAM? gold dome tweeter
    Product External Dimensions:
    (H x W x D) 375 x 230 x 300 mm
    (14 3/4 x 9 1/16 x 11 13/16 inch)
    Individual Weight: 9.5 Kg (20.88 lb)
    Adcom GFP-750
    Adcom GFA-555II
    NAD T585 SACD
