Volume Issues
alegassie2
I recently inherited a Yamaha YP-D71, and after hooking it up, I discovered that even at the highest volume level of my stereo, the sound is still very low. I plugged it into a stereo with just the red and white output.
Any advice?
Any advice?
Post edited by alegassie2 on
What input is it plugged into? You will need to plug that TT into a phono preamp or phono input of your receiver or the signal will be very low. A phono pre provides the necessary gain and eq (riaa equalization) that turntables require.2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
