wall mounts for front heights
Can someone suggest a good bracket for that? I went though hundreds already and can't seem to find one that can do the job.
i want to buy this
http://www.bestbuy.com/site/Dynex%26%23153%3B+-+Adjustable+Wall+Mount+for+Most+Speakers+(2-Pack)+-+Black/9936459.p;jsessionid=63B2240C4D6E4A2B186025DF6943B016.bbolsp-app05-44?id=1218197747640&skuId=9936459
but i don't know how the speaker is attached to it. I have klipsch SB1 bookies for front heights and they have thread on the back. So the wallmount has to have a bolt to go through the thread and also must be adjustable because the front heights will have to face down.
Found many adjustable ones but they don't have the bolt. May be the bolt is not in the picture? I don't know. Suggestions appreciated.
i want to buy this
I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.
jeremymarcinko wrote: »But as in all things your perception is your reality.
Post edited by ravaneli on
How heavy are the speakers? If they are less than 12 lbs, definitely check out the Pinpoint AM20:
http://www.pinpointmounts.com/am20.html
Very popular where I am and everyone seems to love em. I know Crutchfield and Amazon has em. -
Those should have a 1/4 by 20 mounting screw that goes imto the back of the sb1 i have them and as long as you hit a beam in the wall they will be fine. Do u have a stud finder? If not home depot sell cheep ones for 10 to 15.00. Easy to use. Find the beam ( stud) in the wall and mount to that. The brackets should have full instructions and a template for the wall mount side. Simple to mount.just very important to hit the stud!!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
these look very nice. I would buy them right away if I knew for sure they have the mounting screw. How can i confirm that?I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.jeremymarcinko wrote: »But as in all things your perception is your reality.
Contact the sellers customer service amd ask. What u need is a 20 by 1/4" threaded screw mount.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
i went ahead and bought them. I saw some pictures with installations via the screw so i assume it is included. i hope i don't have to return them ..I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.jeremymarcinko wrote: »But as in all things your perception is your reality.
