Please help on my setup.
tension
tension Posts: 4
edited July 2012 in Speakers
I want to setup a system for Karaoke and music. I'm looking at Polk RTI A9 to go with Onkyo nr709 receiver. Are these good enough or I need to add something else? Any advise are appreciated.
Post edited by tension on
  • zane77
    zane77 Posts: 1,696
    edited July 2012
    That will work but to get the most out of the A9's you might want to get an amplifier to drive them. they really like a power amp.
    Two Channel
  • tension
    tension Posts: 4
    edited July 2012
    zane77 wrote: »
    Any recommend for the power amp to go with it or choose a different receiver?
  • zane77
    zane77 Posts: 1,696
    edited July 2012
    I use an Emotiva XPA-2 to drive mine and I really like how they sound. As long as the receiver has pre-outs you will be able to use that as a pre-amplifier.
    Two Channel
  • tension
    tension Posts: 4
    edited July 2012
    If I go with Emotiva XPA-2 do you think it will work if i buy a low end receiver?
  • zane77
    zane77 Posts: 1,696
    edited July 2012
    As long as the receiver has pre-outs. But those are very nice speakers I wouldn't go with a really inexpensive receiver
    Two Channel
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited July 2012
    Just a little advice from a guy who took the long way around to finely get a setup I enjoy.Buy the best you can afford,if that means saving for a while to get what you want do it.Think about used, good bang for the buck can be had with If you take your time.If you buy low end you will want to upgrade,it becomes an itch you just have to scratch.Just my two cents.Dan
  • ViperZ
    ViperZ Posts: 2,046
    edited July 2012
    If you're going a 2-channel route, why do you need a receiver? Buy a really good integrated amplifier, or 2-channel preamp along with 2-channel amp. People on this forum had great results with Adcom, Carver, B&K amps, which are fairly inexpensive. Any good 2-channel amp work - I like Rotel amps =P
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • ravaneli
    ravaneli Posts: 530
    edited July 2012
    you don't need preamp or receiver at all. I have a setup in my garage, my iphone has a 3.5mm out which splits to left and right RCA. The RCA goes straight in my amp and it sounds really good to me. The only thing I notice is that if I play pandora from my PC with the same amp and same speakers it is louder that from my iphone. Quality is the same though. I have all processing turned off on my receivers anyway..
    I am not recommending anything, just saying it's possible.
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2012
    ravaneli wrote: »
    And exactly what will he plug his karaoke device into? Just about all Karaoke devices (especially the home type) are just DVD/ LD players with RCA outputs and no volume controls. Did you expect him to play it at 100% volume all the time?
    Also, who cares if you hooked your iPhone's crappy headphone output directly to an amp? Sure it works but the output is far from stellar. And on top of it, it has absolutely no bearing on the OP, and contributes nothing. No one's singing karaoke from their iphone.
    Main Surround -
  • tension
    tension Posts: 4
    edited July 2012
    I get the idea of the Power Amp but do you think that i should get any center and surround speaker or maybe a sub to get the sound for karaoke?
  • ViperZ
    ViperZ Posts: 2,046
    edited July 2012
    tension wrote: »
    2.1 setup is more than enough for what you need IMHO
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • zane77
    zane77 Posts: 1,696
    edited July 2012
    I think with a good power amp the A9'sill go plenty low enough for karaoke without the need for a sub
    Two Channel
  • ravaneli
    ravaneli Posts: 530
    edited July 2012
    nguyendot wrote: »
    You don't know if it has volume control or not. I can use my PC for caraoke, my ipad, iphone, a lot of things. I am not sure that karaoke devices have no volume controls either.
    BlueFox wrote: »
  • ravaneli
    ravaneli Posts: 530
    edited July 2012
    on a separate note, i would agree that a 2.0 with amp powered A9s should sound more than good enough for most folks.
    BlueFox wrote: »
    tonyb Posts: 33,066
    edited July 2012
    tension wrote: »
    Depends......is this for home use, a bar, a 4000 sq ft basement ? Home audio speakers aren't all that great for Karaoke. Do you plan on hooking up a microphone ? If so, how ? The higher pitches of a microphone won't do home speakers any favors.
    Use pro gear for the singing, it's built to take that abuse.
  • ravaneli
    ravaneli Posts: 530
    edited July 2012
    You know, since a few months ago every time I go to a club or a bar I've been checking the speakers. They are Behringer in 99% of the time. They always sound bad, sometimes it literally hurts the ears, like in the Rivers Casino club. I have two pro amps right now and tested another two and they all played nice with my A7s so my personal opinion is that pro audio amps are good, but these behringer speakers, boy those are horrible. And when they turn them up loud it only underlines the unpleasant parts. I love to take risk and explore and give all gear the benefit of the doubt, but I have to admit I have absolutely no interest in pro audio speakers.
    BlueFox wrote: »
  • nguyendot
    edited July 2012
    ravaneli wrote: »
    listen, lil dude, take a hike and chill. You don't know if it has volume control or not. I can use my PC for caraoke, my ipad, iphone, a lot of things. I am not sure that karaoke devices have no volume controls either. And exactly what did your post contribute. Getting a little impatient with lil dudes like u manning up on the internet. I made a simple post and u enter the thread just to clear your personal grudges. As a matter of fact you are the one who has been making preposterous audio statements and you'd better check your own posts pal, cos your output has been less than stellar too
    Seriously, I've done quite a bit of karaoke in my day. He said he wanted to set up a karaoke system, not play with an iPad/iPod. You can tell from his selection of speakers, he'll probably need a preamp. You basically came in saying "oh hey, you can get away with one...just sayin'" like it's supposed to help him or something.
    As for why they use pro audio speakers for karaoke? That's because the sound levels generally associated with karaoke are very high, and spike to levels that are generally ear bleeding and would ruin most home gear. Being in a studio is one thing, but most home karaoke gear is set up improperly and will result in damaged speakers without attenuation.
    Main Surround -
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2012
    To the OP, get yourself a nice Preamp and an Amplifier and you will be far better off than the Onkyo. Those speakers will sound best with a separate amp to drive them.
