RTA 11TL High Passive Radiator "crackle"
BlueSmoke
BlueSmoke Posts: 5
edited August 2012 in Troubleshooting
First Post! I picked up a pair of RTA-11TL speakers (minty...or so I thought) in May.
I had noticed in casual listening, that I would get an occasional "crackle" from one side. Being a positive sort, I figured it was due to questionable power, or numerous other low end amp issues (I have a fairly low rent sony reciever I use to push these while I build a 2 channel system to truly push them properly.)
Today, since I was inspired:
1. Made a sweep tone CD.
2. Determined the problem exists just in one speaker (after switching cabs to make sure the problem did not exist in the amp...and the second speaker performs fine on the same amp channel with the same source material.)
3. Problem APPEARS to be isolated to the mid passive radiator (with the small cap)
4. Noticed the passive radiator was slightly "crunchy" pushing it in.
5. Pulled speaker. Ran sine tone again. No additional weirdness. (though wacky sounding without the speaker in the cab.)
Thoughts to trouble shoot further? Source for new passive radiator? Go Fish?
Thanks!
Post edited by BlueSmoke on
  • 20hz
    20hz Posts: 636
    edited July 2012
    weird I always that the passive radiator would outlast the speaker !
    I see the radiators on ebay about once a month .
  • skrol
    skrol Posts: 3,480
    edited July 2012
    Welcome to club Polk.
    The PR's have a spider spring that has a cloth covering like a regular speaker. I have seen some Mid-woofers where this cloth detached from the basket and will make noise. This could happen to the PR's too. Fortunately, it can be re-glued to the basket.
    Another possibility is that some foreign object found its way into the back end of the PR.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • ambiophonics
    ambiophonics Posts: 727
    edited July 2012
    You probably just need to push it with an amp with more NADs...
    Another possibility is that the gasket on that passive failed and allowed the factory installed blue smoke to escape... New gaskets will run you about $9.95.
    In all seriousness - welcome to the forum
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
    F1nut Posts: 52,145
    edited July 2012
    That's exactly what the problem is.
  • kcoc321
    kcoc321 Posts: 1,788
    edited July 2012
    skrol wrote: »
    Stan
    That is what I was thinking....some dead mice bones are 'crinkling' in there..LOL
    Course maybe they are stuffed with $100 bills :)
  • BlueSmoke
    BlueSmoke Posts: 5
    edited July 2012
    20hz wrote: »
    Success! Nabbed one for 25 shipped. Will hope that solves the issue, and attempt to repair the other for a spare if things go well!
  • BlueSmoke
    BlueSmoke Posts: 5
    edited July 2012
    Update: New PR arrived. Installed. Still crackles.
    Changed power source to Carver Cube. Still crackles (though sounds MUCH better than the stock NAD 7150 power amp.)
    Installed "defective" PR into speaker into other speaker: No crackle. (Very interesting.)
    Installed working PR into original speaker: Crackles. (doh!)
    Any more thoughts? The crackle kicks in at the low end of the range (I would suspect 45-50 hz) at all volume levels.
    -BlueSmoke
  • Face
    Face Posts: 14,340
    edited July 2012
    Check the rest of your cabinet for leaks.
    F1nut Posts: 52,145
    edited July 2012
    Face wrote: »
    Good idea.
    Another thought, it's not the PR you are hearing, but rather the mid-driver.
  • DaveHo
    DaveHo Posts: 3,583
    edited August 2012
    Are you sure there's nothing touching the back of the passive or mid-woofers? Speaker wire, batting, etc.
  • skrol
    skrol Posts: 3,480
    edited August 2012
    DaveHo wrote: »
    Very good point.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • BlueSmoke
    BlueSmoke Posts: 5
    edited August 2012
    Ok: rattles exorcized.
    Switched original PR's back into speakers. Pulled the lower mid driver on the offending cab. Re-glued seals on back of speaker (as they tore when removing the speaker.) Rotated driver 90 degrees. Reinstalled.
    Noise GONE. Some wires must have been rattling against things.
    Anyone need a spare PR? :cheesygrin:
