Mixing (and Driving) 4 and 8 Ohm Speakers
Fireworks
Fireworks Posts: 3
edited July 2012 in Speakers
I have received wonderful advice on this forum in the past and am hoping someone can help me with a recent setup issue. I have Lsi-25s up front, Lsi-Fxs in the rear and a Pioneer Elite SC-61 receiver. I have yet to hook it up as I am in the process of moving and all the components are new.
I have two questions:
1. What center channel do I get? I tried unsuccessfully to find an Lsic and am now looking at the new Lsi M704c center channel. The Lsic is 4-ohm (as are the rest of my speakers) while the 704c is 8-ohm. Does it matter? I understand timbre matching is important but the m704c may be my only option and I want to make sure I can mix 4 and 8 ohm speakers.
2. Can my Pioneer Elite SC-61 drive this setup? The receiver puts out 200 watts/channel @ 4 ohms (7.1 channel Class D3 amplifier) which, according to posts I have seen here should be sufficient. It also helps, I think, the Lsi-25s have separately powered subwoofers. I'm not gonna rock the house but I do want sufficient sound (and quality).
Thank you. I look forward to a reply.
Post edited by Fireworks on
    EndersShadow Posts: 17,745
    edited July 2012
    Fireworks I would suggest posting a "Wanted" ad in that section for an LSiC. There might be one floating around someone might consider selling. I would also constantly check Polks ebay site for one as it there might be one that pops up. In addition you might try giving them a call to see if they have one on site that hasnt been posted just yet...
  • ravaneli
    ravaneli Posts: 530
    edited July 2012
    Yes, 'wanted' is a good idea.
    Your receiver will be fine driving those speaker. Mixing impedances doesn't matter as long as your receiver is rated for the lowest of them. That 4 ohm or 8 ohm is just a category name, all speakers have different impedances anyway and even the same speaker has different impedance at every frequency and the range is pretty wide.
    Still, when driving 4-ohm speakers with AVR I wouldn't push too high even if rated for 4 ohm..
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • Fireworks
    Fireworks Posts: 3
    edited July 2012
    Thanks for the replies. I ordered the lsic from two websites only to have each order cancel because they were out of stock. I did respond to an ad today on Craigslist and hope it doesn't fall through. If it does, I'll post a Wanted. Sounds like both of you agree I should opt for the lsic over the lsim.
