Annoying , Slight Ground Loop
wingnut4772
wingnut4772 Posts: 7,519
edited July 2012 in Troubleshooting
I have a ground loop issue. It is really very slight though. I have to put my ear to the speakers to hear it. Is that acceptable , normal or common? I can't seem to isolate it.
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Post edited by wingnut4772 on
  • bencorn
    bencorn Posts: 49
    edited July 2012
    I had a really bad ground loop when I put my new subwoofer in. I tried the ground loop isolators and multiple other tricks I'd read about online. The only thing I found that worked was to use a 2 prong power cord for the sub instead of 3 prong, ground loop gone. Best way to find it is to unplug your equipment and start with just the bare essentials and keep adding equipment until the hum starts. Start with just the receiver and speakers with nothing else, if it hums it's the receiver causing an issue. If nothing add another piece of equipment and so forth. I got lucky and I unplugged the sub first and the sound disappeared so I knew it was the culprit.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited July 2012
    I had the same kind of problem some time ago. With my hum, found that the TV in the bedroom being plugged into a 3 prong socket was the problem. It was feeding through the sat. receiver in the bedroom, through the coax, and back into the sat receiver in the main system. When I first started looking for the problem, was looking in the main system. Found disconnecting the incoming coax from the sat antenna to the receiver made the hum go away. Tried everything I could think of to remedy the situation with no success. Then quite by accident, was changing something out in the bedroom, and discovered where the hum was coming from. Ground loops can be a PITA! Best of luck finding and getting rid of yours.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • Thorton
    Thorton Posts: 1,324
    edited July 2012
    I had a good hum when I added my amp. I followed the detective role procedure that bencorn outlined to identify the amp as the culprit. I tried a cheater plug (suggested in many threads) that did solve the problem. I eventually bought a Ebtech HumX to replace the cheater plug. Problem gone. Good luck!
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
    edited July 2012
    Have to agree with some of the guys above. When I first got my Nak CA-5 pre-amp and plugged her in--ground loop hum. Big time! Of course all that equipment is close to cable boxes and TV, etc. So out came the CHEATER plug (3 prong to 2)--problem solved!
    Hope it's that easy for you!
    cnh
    edited July 2012
    Actually Darla, I'm kinda surprised given your gear list over the years, you haven't experienced ground loops more often. Even the slightest hum would bug me to no end. If your not using a good power conditioner, a cheater plug as mentioned above would also work but you may need to try it on a few different pieces. I always start with the receiver, then the amps, and source last.
  • GlennDog
    GlennDog Posts: 3,158
    edited July 2012
    cnh wrote: »
    So out came the CHEATER plug (3 prong to 2)--problem solved!cnh
    I've had HUM issues in the past and what solved my problem (then) was to use a Tributaries Ground Guard . . .
    Wouldn't removing the ground (with the cheater) be akin to playing Russian Roulette with your equipment? (like if there were "ground issues, like a lightning strike etc" . . . just a thought . . .
    G
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • 20hz
    20hz Posts: 636
    edited July 2012
    That sounds like my cheater plug on the amp may be a bad idea , what about a seperate ground ?
    All foundations have a piece of rebar sticking out under the house what if you just grounded that humming item to it ?
    And used a surge protector of coarse , that way it gets ground ( a surge protector only works with one ) . I am thinking since rca's get a common ground it may not work but it worth a try ?
    GlennDog wrote: »
    G
